メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
GE Front Load Washing Machine Dispenser Assembly Replacement
ビデオガイド
この修理ガイドはYouTubeビデオを書き起こしました。
必要な工具と部品
    • Pull the dispenser drawer forward until it stops.
    • Press firmly on the tab at the rear of the drawer and slide the drawer completely out of the housing.
    FixBotに聞いてみる
    コメントを追加
    • Use a Phillips screwdriver to extract the five screws now exposed in the dispenser opening.
    • Keep the coarse-thread middle screws separate from the fine-thread top and bottom screws.
    FixBotに聞いてみる
    コメントを追加
    • Lift the left side of the interface about twenty degrees then pivot it to the right and pull it away from the washer.
    • Do not yank; the panel is still tethered by a short wire harness.
    FixBotに聞いてみる
    コメントを追加
    • Press the three harness clips from the inside out if you need more room to maneuver the interface.
    FixBotに聞いてみる
    コメントを追加
    • Unscrew the water valve assembly and pivot it upward to gain clear access to the dispenser body.
    • This procedure is easier on GFW-550 models than on GFW-650 and larger machines.
    FixBotに聞いてみる
    コメントを追加
    • Unhook the wire harness from the dispenser body.
    • Release the top hoses that run between the water valves and the dispenser ports.
    • Slide the dispenser toward the rear to unlatch its right side from the chassis.
    FixBotに聞いてみる
    コメントを追加
    • Loosen the clamps and pull off the four or five hoses attached to the back of the dispenser box.
    • If a hose is stuck, slip a flat screwdriver between the rubber hose and the plastic barb to break it free.
    FixBotに聞いてみる
    コメントを追加
    • Remove the three screws underneath the washer to release the lower edge of the front panel.
    • Extract the seven screws securing the panel to the bulkhead.
    • Unscrew the two screws holding the door-lock facade and the single screw securing the lock.
    • Lift the lock upward and push it rearward so it will not snag the panel.
    FixBotに聞いてみる
    コメントを追加
    • Open the washer door, lift the panel upward, and pivot it away from the machine.
    • Disconnect the wire harness on the left side before fully removing the panel.
    FixBotに聞いてみる
    コメントを追加
    • Remove the spring clamp and pull the primary tub hose off the dispenser spigot.
    • Disconnect the drain hose at the underside rear of the dispenser.
    • Release the small hose behind the metal plate next to the dispenser box.
    FixBotに聞いてみる
    コメントを追加
    • With all eight hoses free, slide the dispenser box out of the cabinet.
    • Inspect or clean the box now, or set it aside if you are installing a new unit.
    FixBotに聞いてみる
    コメントを追加
    • Unclip the reed switch from the underside of the old dispenser and install it in the same location on the replacement box.
    FixBotに聞いてみる
    コメントを追加
    • Feed the rear drain hose onto the dispenser first before the box is fully seated.
    • Slide the dispenser into the front bulkhead opening and hold it in place.
    FixBotに聞いてみる
    コメントを追加
    • Attach the remaining seven hoses one by one, securing each clamp firmly.
    • Work patiently; reinstalling the hoses usually goes faster than removal.
    FixBotに聞いてみる
    コメントを追加
    • Route the harnesses into the molded channels on the dispenser body.
    • Slide the dispenser rearward until its rear hooks click into the washer chassis.
    FixBotに聞いてみる
    コメントを追加
    • Reconnect the large front hose, aligning the molded notch with the dispenser groove.
    • Confirm the small alignment finger rests on the bulkhead to guide the dispenser box.
    FixBotに聞いてみる
    コメントを追加
    • Lift the door panel onto its four locator pegs and push it flush with the cabinet.
    • Reconnect the left-side harness, then replace the upper and lower mounting screws.
    FixBotに聞いてみる
    コメントを追加
    • Ensure the top damper is fully seated, then install its three mounting screws.
    • Roll the door gasket lip over the rim and wear gloves to avoid cuts.
    FixBotに聞いてみる
    コメントを追加
    • Expand the spring with a door gasket spring tool and guide the wire around the gasket groove.
    • Use a small hook or screwdriver to press the wire fully home before releasing the tool.
    FixBotに聞いてみる
    コメントを追加
    • Position the door lock on its bracket and secure it with its screw.
    • Reattach the plastic facade using its two screws.
    FixBotに聞いてみる
    コメントを追加
    • Hook the interface onto the right-side post, pivot it down, and snap it into place.
    • Install the two coarse-thread center screws and the three fine-thread outer screws while holding the dispenser box flush.
    FixBotに聞いてみる
    コメントを追加
    • Slide the dispenser drawer back onto its rails until it clicks fully home.
    FixBotに聞いてみる
    コメントを追加
    • Lower the top panel onto the chassis and secure it with its rear screws.
    FixBotに聞いてみる
    コメントを追加
終わりに
Repair didn't go as planned? Ask our Answers community for help.
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Ben Schlichter
メンバー登録日: 01/21/25
6,554 ポイント
224のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 40
過去 30 日: 154
今までの合計 562
