メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
GE Front Load Washing Machine Disassembly
ビデオガイド
この修理ガイドはYouTubeビデオを書き起こしました。
必要な工具と部品
    • Pull the dispenser drawer fully out and press the rear tab to release it.
    • Remove the five screws from the dispenser housing using a screwdriver with a magnetic tip.
    • Make sure the two center screws are fully backed out before pulling the console. They can rethread themselves if left partially engaged.
    FixBotに聞いてみる
    コメントを追加
    • Lift the left edge of the console slightly, then push it to the right to free it.
    • Confirm all dispenser screws are removed or they may block console movement.
    FixBotに聞いてみる
    コメントを追加
    • Remove the three small screws at the top of the washer behind the console area.
    • Slide the top panel forward and lift it away to expose the machine’s interior.
    • Remove or loosen wire ties with pliers or disconnect the console harness for more slack if needed.
    FixBotに聞いてみる
    コメントを追加
    • Use a small flathead screwdriver to pry off the outer door-boot retaining spring, then peel the boot edge away from the bulkhead.
    • Watch for sharp metal edges on the bulkhead while releasing the door boot.
    • Remove the two screws securing the plastic trim on the door-lock side.
    • Remove the two screws beneath the trim to free the door lock from the bulkhead.
    FixBotに聞いてみる
    コメントを追加
    • Remove the screws along the top and sides of the bulkhead, including the screws near the dispenser area.
    • If needed, tilt the washer slightly to loosen the three screws underneath.
    • Support the washer if tilted because it is heavy and can shift unexpectedly.
    • Remove the three screws securing the air baffle, then slide it away from the bulkhead.
    • Disconnect the wire harness on the left side before pulling the bulkhead forward.
    FixBotに聞いてみる
    コメントを追加
    • Reconnect the left-side wire harness behind the bulkhead before lowering the bulkhead into place.
    • Lift the bulkhead above the chassis and lower it onto the plastic mounts.
    • Align the blower fan part of the door boot with the slots on the bulkhead and secure them.
    • Reinstall all bulkhead screws, working from the outside edges in toward the center.
    FixBotに聞いてみる
    コメントを追加
    • Fit the door lock into position on the bulkhead and secure it with two screws.
    • Place the plastic facade over the lock and attach it with two more screws.
    • Pull the door boot onto the metal lip of the bulkhead, ensuring a tight channel fit.
    • Use a Smart Wrench to stretch the large door-boot spring back into place.
    FixBotに聞いてみる
    コメントを追加
    • Reseat the top panel on the washer and secure it with the three upper-edge screws.
    • Align the console with the two flat-head screws on the right side and lower it in place.
    • Push the console left until it snaps fully and locks into position.
    • Reinstall the five dispenser housing screws, noting that two middle screws are larger.
    • Slide the dispenser drawer back in until the rear tab clicks securely.
    FixBotに聞いてみる
    コメントを追加
終わりに
Repair didn't go as planned? Ask our Answers community for help.
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Ben Schlichter
メンバー登録日: 01/21/25
7,100 ポイント
224のガイドは作成済み
1件のガイドコメント
These instructions don't match the screws I have once the dispenser is removed. My model is GE GFW480SSKWW 28" 4.9 cu. ft. Front Load Steam Washer
John Walsh - 返信 共有
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 48
過去 30 日: 288
今までの合計 3,214
