メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
GD Midea FT30-3D Power/Speed Switch Replacement
必要な工具と部品
    1. GD Midea FT30-3D Power/Speed Switch Replacement, Bottom Base: 手順 1、 1の画像 1
      • Locate and remove the 14.5 mm Phillips #1 screw on the bottom of the fan base.
      FixBotに聞いてみる
      コメントを追加
    2. GD Midea FT30-3D Power/Speed Switch Replacement: 手順 2、 2の画像 1 GD Midea FT30-3D Power/Speed Switch Replacement: 手順 2、 2の画像 2
      • Locate the gray base support release tabs found on either side pictured in the first image.
      • There are release tabs on each side of the base.
      • Press both release tabs in with the tip of your fingers and pull the gray base support until the tabs are cleared.
      FixBotに聞いてみる
      コメントを追加
    3. GD Midea FT30-3D Power/Speed Switch Replacement: 手順 3、 1の画像 1
      • Continue removing the gray base support by pressing your thumb into the circular opening in the base and pulling with your figures on the back side.
      • Notice that on the internal front tip of the base there is a tab. Because of this tab the back end will pivot off at that point.
      FixBotに聞いてみる
      コメントを追加
    4. GD Midea FT30-3D Power/Speed Switch Replacement: 手順 4、 1の画像 1
      • After the base has separated more it will be easy to fully remove it. Continue pulling the back edge of the gray base support, rotating it around the front tab until it comes off completely.
      FixBotに聞いてみる
      コメントを追加
    5. GD Midea FT30-3D Power/Speed Switch Replacement: 手順 5、 1の画像 1
      • Remove the following five 14.5 mm Phillips #1 screws found on the bottom.
      • All of the screws are recessed by 17.5 mm, so ensure your screwdriver can reach that far.
      FixBotに聞いてみる
      コメントを追加
    6. GD Midea FT30-3D Power/Speed Switch Replacement: 手順 6、 1の画像 1
      • Once all five screws have been removed the base cover should fall right off with out any effort.
      • When putting the base cover back on; be careful to make sure that none of the wires are pinched.
      FixBotに聞いてみる
      コメントを追加
    1. GD Midea FT30-3D Power/Speed Switch Replacement, Power/Speed Switch: 手順 7、 1の画像 1
      • Remove the two 10 mm Phillips #1 screws found connecting the switch to the case.
      • Notice the AC power cord line (white wire) goes into the switch under the [Off] button
      FixBotに聞いてみる
      コメントを追加
    2. GD Midea FT30-3D Power/Speed Switch Replacement: 手順 8、 1の画像 1
      • Take the 1.5 mm Flathead Screwdriver, or any thin elongated tool that fits into the semi-circular holes along side the wires. Press into the hole gently to release the grip on the wires.
      • The wires should release with ease if done properly.
      • When reassembling; skip this step.
      FixBotに聞いてみる
      コメントを追加
    3. GD Midea FT30-3D Power/Speed Switch Replacement: 手順 9、 1の画像 1
      • Take the new switch, and simply push the wiring into the correct holes:
      • AC Power Cord (white wire)
      • Low speed (gray wire)
      • Medium speed (orange wire)
      • High speed (red wire)
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Alan Su
メンバー登録日: 10/03/12
846 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 24-28, Regan Fall 2012 Cal Poly, Team 24-28, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S24G28
4 メンバー
45のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 45
今までの合計 4,332
