メインコンテンツにスキップ
Fusion5 5.5 Gen II Top Speaker Replacement
必要な工具と部品
  1. Fusion5 5.5 Gen II Top Speaker Replacement, Back Cover: 手順 1、 2の画像 1 Fusion5 5.5 Gen II Top Speaker Replacement, Back Cover: 手順 1、 2の画像 2
    • Hold the device with the screen facing away from you and the back of the device facing you.
    • Locate the groove at the bottom corner of the device.
    • Begin prying the back cover of the device off from the groove and working your way around the outside edges of the device.
  2. Fusion5 5.5 Gen II Top Speaker Replacement, Midframe: 手順 2、 2の画像 1 Fusion5 5.5 Gen II Top Speaker Replacement, Midframe: 手順 2、 2の画像 2
    • Remove thirteen 3mm Phillips #00 screws from the midframe.
    • Remove the single 5mm Phillips #0 screw below the camera.
  3. Fusion5 5.5 Gen II Top Speaker Replacement: 手順 3、 2の画像 1 Fusion5 5.5 Gen II Top Speaker Replacement: 手順 3、 2の画像 2
    • Using an opening pick, begin prying one of the top corners to remove the midframe from the device.
    • Be careful not to damage the cables inside the device when you pry the midframe off.
  4. Fusion5 5.5 Gen II Top Speaker Replacement, Motherboard: 手順 4、 1の画像 1
    この手順で使用する道具:
    • Using tweezers, flip the brown tab securing the ribbon cable.
    • Make sure to only lift the flap and not the connector socket due to its susceptibility to break off.
    • Grab the ribbon cable with the tweezers and pull it from its socket on the motherboard.
  5. Fusion5 5.5 Gen II Top Speaker Replacement: 手順 5、 1の画像 1
    • Remove the two 3mm Phillips #00 screws from the motherboard.
  6. Fusion5 5.5 Gen II Top Speaker Replacement: 手順 6、 1の画像 1
    • Grab the motherboard from the right edges.
    • Flip the motherboard to the left side of the device.
    • Be careful not to tear the cables attached to the motherboard as you flip the motherboard.
    • Desolder the red and blue wires to remove the motherboard from the device.
  7. Fusion5 5.5 Gen II Top Speaker Replacement, Top Speaker: 手順 7、 2の画像 1 Fusion5 5.5 Gen II Top Speaker Replacement, Top Speaker: 手順 7、 2の画像 2
    この手順で使用する道具:
    • Using tweezers, grasp the speaker at the top of the phone and gently pull it out of the device.
終わりに
作成者
5人の作成者と共同で作成されました。
Hwajin
メンバー登録日: 09/16/19
566 ポイント
5のガイドは作成済み
チーム
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 407
