はじめに
This guide shows how to replace the camera lens of the Furbo Dog camera (Model:2). Be sure that you are working on the Camera and not the other components that are very close to it!
必要な工具と部品
この手順で使用する道具:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
