メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Fujtsu Lifebook Model A6110 Keyboard Replacement
必要な工具と部品
    1. Fujtsu Lifebook Model A6110 Keyboard Replacement, Battery: 手順 1、 2の画像 1 Fujtsu Lifebook Model A6110 Keyboard Replacement, Battery: 手順 1、 2の画像 2
      • The computer should be fully turned off and disconnected from the power source.
      • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
      • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
      FixBotに聞いてみる
      コメントを追加
    2. Fujtsu Lifebook Model A6110 Keyboard Replacement: 手順 2、 1の画像 1
      • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
      FixBotに聞いてみる
      コメントを追加
    1. Fujtsu Lifebook Model A6110 Keyboard Replacement, Keyboard: 手順 3、 3の画像 1 Fujtsu Lifebook Model A6110 Keyboard Replacement, Keyboard: 手順 3、 3の画像 2 Fujtsu Lifebook Model A6110 Keyboard Replacement, Keyboard: 手順 3、 3の画像 3
      • Position the laptop like you would if you were to use it. Open the screen to a 180 degrees angle. The screen and the keyboard needs to face up before proceeding.
      • Using a flat edge of the plastic spudger, gently lift the piece of plastic located in the red square. Carefully insert the spudger between the inner edge marked by the arrow.
      FixBotに聞いてみる
      コメントを追加
    2. Fujtsu Lifebook Model A6110 Keyboard Replacement: 手順 4、 3の画像 1 Fujtsu Lifebook Model A6110 Keyboard Replacement: 手順 4、 3の画像 2 Fujtsu Lifebook Model A6110 Keyboard Replacement: 手順 4、 3の画像 3
      • With a Phillips #1 screwdriver, unscrew the four-six mm screws that were hidden under the plastic piece you removed.
      FixBotに聞いてみる
      コメントを追加
    3. Fujtsu Lifebook Model A6110 Keyboard Replacement: 手順 5、 3の画像 1 Fujtsu Lifebook Model A6110 Keyboard Replacement: 手順 5、 3の画像 2 Fujtsu Lifebook Model A6110 Keyboard Replacement: 手順 5、 3の画像 3
      • Lift up on the inner edges of the hinges for the screen. This will detach the face-plate from the computer. Use a spudger to make this process easier.
      • There is a ribbon underneath this panel that attaches to the motherboard. Be careful to not rip this ribbon.
      • The ribbon is located in the top left-hand corner and needs to carefully disconnected from the motherboard, as shown in the next step.
      FixBotに聞いてみる
      コメントを追加
    4. Fujtsu Lifebook Model A6110 Keyboard Replacement: 手順 6、 2の画像 1 Fujtsu Lifebook Model A6110 Keyboard Replacement: 手順 6、 2の画像 2
      • Detach the ribbon from the motherboard, which will allow you to finish removing the face-plate from the computer.
      • To detach the ribbon, grip the ribbon at the base that is attached to the motherboard, which is the large green circuit-board in the body of the computer.
      • When reassembling the computer, make sure to reconnect the ribbons.
      FixBotに聞いてみる
      コメントを追加
    5. Fujtsu Lifebook Model A6110 Keyboard Replacement: 手順 7、 2の画像 1 Fujtsu Lifebook Model A6110 Keyboard Replacement: 手順 7、 2の画像 2
      • There is another ribbon connecting the keyboard to the motherboard. Be careful not to rip it
      • The keyboard is now free. Lift up on the keyboard.
      FixBotに聞いてみる
      コメントを追加
    6. Fujtsu Lifebook Model A6110 Keyboard Replacement: 手順 8、 1の画像 1
      • This ribbon may be difficult to remove, so be careful in pulling it. You could accidentally break it.
      • Detatch the ribbon from the motherboard
      • When reassembling the computer, make sure to reconnect this ribbon.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Cody Moniz
メンバー登録日: 10/19/16
422 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 UMass Dartmouth, Team 3-2, Isaacson Fall 2016人のメンバー
UMASSD-ISAACSON-F16S3G2
3 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 25
今までの合計 1,049
