メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Fujitsu LIFEBOOK P7010D Monitor Replacement
必要な工具と部品
  1. Fujitsu LIFEBOOK P7010D Monitor Replacement, Battery: 手順 1、 1の画像 1
    • Place the laptop upside down on a table.
    FixBotに聞いてみる
    コメントを追加
  2. Fujitsu LIFEBOOK P7010D Monitor Replacement: 手順 2、 1の画像 1
    • Locate the battery (the grey block). Find the two tabs on one end of the battery, as pictured.
    • Using two fingers, press both tabs down at once until they are fully depressed.
    FixBotに聞いてみる
    コメントを追加
  3. Fujitsu LIFEBOOK P7010D Monitor Replacement: 手順 3、 1の画像 1
    • While holding the tabs down, slowly pivot the battery up.
    • The battery is now free and safe to pull out.
    FixBotに聞いてみる
    コメントを追加
  4. Fujitsu LIFEBOOK P7010D Monitor Replacement, Keyboard: 手順 4、 2の画像 1 Fujitsu LIFEBOOK P7010D Monitor Replacement, Keyboard: 手順 4、 2の画像 2
    • Unscrew three 2.4mm and one 5.7mm screws using a Phillips # 0.
    • Unscrew three 1.9mm screws in the battery compartment still using a Phillips # 0
    FixBotに聞いてみる
    コメントを追加
  5. Fujitsu LIFEBOOK P7010D Monitor Replacement: 手順 5、 3の画像 1 Fujitsu LIFEBOOK P7010D Monitor Replacement: 手順 5、 3の画像 2 Fujitsu LIFEBOOK P7010D Monitor Replacement: 手順 5、 3の画像 3
    • Mind the wire connections on the bottom right side of the monitor. They are still connected between the monitor and computer.
    • Raise the monitor as you normally would until it pops out by itself. Rotate the left side up and to the right to unhook hinges that may catch on the computer.
    • Lay the monitor flat next to the computer.
    FixBotに聞いてみる
    コメントを追加
  6. Fujitsu LIFEBOOK P7010D Monitor Replacement: 手順 6、 2の画像 1 Fujitsu LIFEBOOK P7010D Monitor Replacement: 手順 6、 2の画像 2
    この手順で使用する道具:
    Anti-Static Wrist Strap
    $7.95
    • Using a smaller spudger (like a PX3688), pivot the sound case out above the "F2" and "Insert" buttons.
    • Lift the case out and set it aside.
    • For the proceeding steps, put on your anti-static wrist strap and attach the metal clip to something metal and grounded in order to protect the delicate circuitry inside the computer.
    FixBotに聞いてみる
    コメントを追加
  7. Fujitsu LIFEBOOK P7010D Monitor Replacement: 手順 7、 3の画像 1 Fujitsu LIFEBOOK P7010D Monitor Replacement: 手順 7、 3の画像 2 Fujitsu LIFEBOOK P7010D Monitor Replacement: 手順 7、 3の画像 3
    • Using the same spudger, pry the top of the keyboard up above the "F2" key.
    • Turn the computer so that the bottom is facing you.
    • The keyboard is connected to a black plastic strip, slowly pull the keyboard and place it to the side.
    FixBotに聞いてみる
    コメントを追加
  8. Fujitsu LIFEBOOK P7010D Monitor Replacement: 手順 8、 2の画像 1 Fujitsu LIFEBOOK P7010D Monitor Replacement: 手順 8、 2の画像 2
    • Disconnect the keyboard by gently pulling on the hard plastic square straight up from the white connector.
    FixBotに聞いてみる
    コメントを追加
  9. Fujitsu LIFEBOOK P7010D Monitor Replacement, Monitor: 手順 9、 3の画像 1 Fujitsu LIFEBOOK P7010D Monitor Replacement, Monitor: 手順 9、 3の画像 2 Fujitsu LIFEBOOK P7010D Monitor Replacement, Monitor: 手順 9、 3の画像 3
    • Peel the white tape from the wires connected to the monitor, but do not completely remove it.
    • Unplug the white and black wires with your fingers.
    FixBotに聞いてみる
    コメントを追加
  10. Fujitsu LIFEBOOK P7010D Monitor Replacement: 手順 10、 3の画像 1 Fujitsu LIFEBOOK P7010D Monitor Replacement: 手順 10、 3の画像 2 Fujitsu LIFEBOOK P7010D Monitor Replacement: 手順 10、 3の画像 3
    • Unplug the white chip connected to the thicker wire with two smaller spudgers (like a PX3688) by wiggling it back and forth until it pops out.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Nicholas Ross
メンバー登録日: 01/20/12
207 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 10-31, Amido Winter 2012 Cal Poly, Team 10-31, Amido Winter 2012人のメンバー
CPSU-AMIDO-W12S10G31
5 メンバー
21のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 28
今までの合計 3,418
