メインコンテンツにスキップ
Framework Laptop 16" Wi-Fi Card Replacement
必要な工具と部品
  1. Framework Laptop 16" Wi-Fi Card Replacement, Before you begin: 手順 1、 2の画像 1 Framework Laptop 16" Wi-Fi Card Replacement, Before you begin: 手順 1、 2の画像 2
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
    • Framework recommends that you put your laptop into battery disconnect mode in the BIOS whenever removing the battery. Read how to do that here.
    • To disable this mode, click here.
  2. Framework Laptop 16" Wi-Fi Card Replacement, Unlock the Input Modules: 手順 2、 3の画像 1 Framework Laptop 16" Wi-Fi Card Replacement, Unlock the Input Modules: 手順 2、 3の画像 2 Framework Laptop 16" Wi-Fi Card Replacement, Unlock the Input Modules: 手順 2、 3の画像 3
    • Use your fingernail to pull out the two Input Module latches and unlock them.
    • The latch will show red if it's unlocked.
  3. Framework Laptop 16" Wi-Fi Card Replacement, Remove the touchpad spacers: 手順 3、 3の画像 1 Framework Laptop 16" Wi-Fi Card Replacement, Remove the touchpad spacers: 手順 3、 3の画像 2 Framework Laptop 16" Wi-Fi Card Replacement, Remove the touchpad spacers: 手順 3、 3の画像 3
    • Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the touchpad spacer off the laptop and remove it.
  4. Framework Laptop 16" Wi-Fi Card Replacement: 手順 4、 1の画像 1
    • Repeat the same procedure for the other touchpad spacer.
  5. Framework Laptop 16" Wi-Fi Card Replacement, Remove the touchpad: 手順 5、 3の画像 1 Framework Laptop 16" Wi-Fi Card Replacement, Remove the touchpad: 手順 5、 3の画像 2 Framework Laptop 16" Wi-Fi Card Replacement, Remove the touchpad: 手順 5、 3の画像 3
    • Use your fingers to slide the touchpad toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the touchpad and remove it.
    • During reassembly, perform the following:
    • Place the touchpad flat on its cutout so its clips are properly aligned.
    • Press the touchpad down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  6. Framework Laptop 16" Wi-Fi Card Replacement, Remove the keyboard: 手順 6、 3の画像 1 Framework Laptop 16" Wi-Fi Card Replacement, Remove the keyboard: 手順 6、 3の画像 2 Framework Laptop 16" Wi-Fi Card Replacement, Remove the keyboard: 手順 6、 3の画像 3
    • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
    • Grip the two pull tabs along the bottom of the keyboard.
    • Lift the pull tabs until the keyboard magnets release.
    • Remove the keyboard.
    • During reassembly, make sure the keyboard is seated properly on its alignment pegs and sits evenly with the edges of the laptop.
  7. Framework Laptop 16" Wi-Fi Card Replacement, Remove the numpad: 手順 7、 3の画像 1 Framework Laptop 16" Wi-Fi Card Replacement, Remove the numpad: 手順 7、 3の画像 2 Framework Laptop 16" Wi-Fi Card Replacement, Remove the numpad: 手順 7、 3の画像 3
    • The numpad is held in place with strong magnets. Apply gradually increasing force to avoid having the numpad violently eject.
    • Grip the pull tab at the bottom of the numpad.
    • Lift the pull tab until the numpad magnets release.
    • Remove the numpad.
    • During reassembly, make sure the numpad is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  8. Framework Laptop 16" Wi-Fi Card Replacement, Disconnect the midframe cable: 手順 8、 2の画像 1 Framework Laptop 16" Wi-Fi Card Replacement, Disconnect the midframe cable: 手順 8、 2の画像 2
    • Grip the black pull tab on the midframe cable press connector.
    • Lift up to disconnect the midframe cable.
  9. Framework Laptop 16" Wi-Fi Card Replacement, Loosen the midframe screws: 手順 9、 2の画像 1 Framework Laptop 16" Wi-Fi Card Replacement, Loosen the midframe screws: 手順 9、 2の画像 2
    • The midframe screws are ordered from 2–17 (number 1 is the press connector). You don't have to follow the order, but you can use it to help keep track of the screws you've loosened.
    • Use a T5 Torx screwdriver to loosen the 16 captive screws securing the midframe.
    • During reassembly, follow the order (starting with 2) to reinstall the screws across the midframe evenly.
  10. Framework Laptop 16" Wi-Fi Card Replacement, Remove the midframe: 手順 10、 2の画像 1 Framework Laptop 16" Wi-Fi Card Replacement, Remove the midframe: 手順 10、 2の画像 2
    • Use your fingernail to lift the bottom edge of the midframe enough to grip it with your fingers.
  11. Framework Laptop 16" Wi-Fi Card Replacement: 手順 11、 2の画像 1 Framework Laptop 16" Wi-Fi Card Replacement: 手順 11、 2の画像 2
    • Lift the midframe off the laptop and remove it.
    • During reassembly, make sure the midframe sits evenly on its alignment pegs before tightening the screws.
  12. Framework Laptop 16" Wi-Fi Card Replacement, Loosen the battery screws: 手順 12、 2の画像 1 Framework Laptop 16" Wi-Fi Card Replacement, Loosen the battery screws: 手順 12、 2の画像 2
    • Use a T5 Torx screwdriver to loosen the three captive screws securing the battery.
  13. Framework Laptop 16" Wi-Fi Card Replacement, Remove the battery: 手順 13、 3の画像 1 Framework Laptop 16" Wi-Fi Card Replacement, Remove the battery: 手順 13、 3の画像 2 Framework Laptop 16" Wi-Fi Card Replacement, Remove the battery: 手順 13、 3の画像 3
    • Grip the black pull tab at the top of the battery.
    • Lift the pull tab to disconnect the battery connector.
    • Remove the battery.
  14. Framework Laptop 16" Wi-Fi Card Replacement, Loosen the Wi-Fi card screw: 手順 14、 2の画像 1 Framework Laptop 16" Wi-Fi Card Replacement, Loosen the Wi-Fi card screw: 手順 14、 2の画像 2
    • Use a T5 Torx screwdriver to loosen the captive screw securing Wi-Fi card.
    • The Wi-Fi card might pop up at a shallow angle when you loosen the screw.
  15. Framework Laptop 16" Wi-Fi Card Replacement, Remove the Wi-Fi card: 手順 15、 2の画像 1 Framework Laptop 16" Wi-Fi Card Replacement, Remove the Wi-Fi card: 手順 15、 2の画像 2
    • Slide the clear Wi-Fi card cover straight off the card and remove it.
  16. Framework Laptop 16" Wi-Fi Card Replacement: 手順 16、 2の画像 1 Framework Laptop 16" Wi-Fi Card Replacement: 手順 16、 2の画像 2
    • Grip the end of the Wi-Fi card with the screw hole and slide it out of its socket.
    • Don't pull the Wi-Fi card too far from its socket, as it's still connected by two cables.
  17. Framework Laptop 16" Wi-Fi Card Replacement: 手順 17、 3の画像 1 Framework Laptop 16" Wi-Fi Card Replacement: 手順 17、 3の画像 2 Framework Laptop 16" Wi-Fi Card Replacement: 手順 17、 3の画像 3
    • Insert the flat end of a spudger under one of the coaxial connectors, where the cable meets the metal head.
    • Lift the spudger straight up to disconnect the coaxial cable.
    • Repeat for the other coaxial cable and remove the Wi-Fi card.
    • During reassembly, refer to the arrows on the Wi-Fi card for which cable (black or white) a connector belongs to.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
ある他の人がこのガイドを完成しました。
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
213,142 ポイント
1,040のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,629のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 65
今までの合計 1,929
