メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Fosera Scandle 200 Power Switch Replacement
必要な工具と部品
    1. Fosera Scandle 200 Power Switch Replacement, Motherboard Removal: 手順 1、 1の画像 1
      • To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
      FixBotに聞いてみる
      コメントを追加
    2. Fosera Scandle 200 Power Switch Replacement: 手順 2、 1の画像 1
      • Gently separate the two halves of the casing.
      FixBotに聞いてみる
      コメントを追加
    3. Fosera Scandle 200 Power Switch Replacement: 手順 3、 1の画像 1
      • Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
      • Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
      FixBotに聞いてみる
      コメントを追加
    4. Fosera Scandle 200 Power Switch Replacement: 手順 4、 1の画像 1
      • Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
      FixBotに聞いてみる
      コメントを追加
    5. Fosera Scandle 200 Power Switch Replacement: 手順 5、 1の画像 1
      • Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
      FixBotに聞いてみる
      コメントを追加
    1. Fosera Scandle 200 Power Switch Replacement, Power Switch: 手順 6、 1の画像 1
      • Locate the Power Switch, and examine the area underneath the yellow plastic.
      • If you find something obstructing the movement, and you can remove it, you're done! If not, proceed with the replacement.
      FixBotに聞いてみる
      コメントを追加
    2. Fosera Scandle 200 Power Switch Replacement: 手順 7、 1の画像 1
      • Locate the three prong connectors for the switch on the back of the motherboard. The correct prongs will be right under the print which reads, "Scandle0410 REV.07"
      FixBotに聞いてみる
      コメントを追加
    3. Fosera Scandle 200 Power Switch Replacement: 手順 8、 1の画像 1
      • The soldering iron WILL be hot! Don't touch the iron's tip or any parts which have recently been in contact with the iron.
      • The solder around all three prong connectors will need to be melted individually. Push the prongs out with the soldering iron as the solder melts.
      FixBotに聞いてみる
      コメントを追加
    4. Fosera Scandle 200 Power Switch Replacement: 手順 9、 1の画像 1
      • Use the flat end of the spudger to pry the power switch from the motherboard. If the switch is still secured, use the pointed end of the spudger to poke the prongs out from the back.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jared
メンバー登録日: 09/23/14
199 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 12-5, Blackwell Fall 2014 USF Tampa, Team 12-5, Blackwell Fall 2014人のメンバー
USFT-BLACKWELL-F14S12G5
4 メンバー
28のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 33
今までの合計 690
