はじめに
This guide will explain and show how to replace a charging terminal that has stopped working. Replacing it requires the use of a soldering iron and the Spudger. This is a fairly easy replacement guide and should only take around fifteen minutes.
必要な工具と部品
To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
Locate the charging terminal's three prong connectors on the back of the motherboard.
ある他の人がこのガイドを完成しました。
