メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Flip MinoHD Display Screen Replacement
必要な工具と部品
    1. Flip MinoHD Display Screen Replacement, Casing: 手順 1、 2の画像 1 Flip MinoHD Display Screen Replacement, Casing: 手順 1、 2の画像 2
      • With the plastic opening tool, remove labels from the Flip Mino HD. 2 small black screws should appear.
      • With the Phillips Screwdriver 000, unscrew the 2 screws and set aside in a safe place.
      FixBotに聞いてみる
      コメントを追加
    2. Flip MinoHD Display Screen Replacement: 手順 2、 2の画像 1 Flip MinoHD Display Screen Replacement: 手順 2、 2の画像 2
      この手順で使用する道具:
      • With the plastic opening tool, gently pry the front casing away from the device by carefully running the tool around each edge and lifting.
      • Do not pull to remove the casing until all sides are loose. You may break or crack the case.
      • Once case is loose, flip up and over the device. Note that casing is still connected to the device.
      • Using tweezers, pull connecting strip to disconnect it from its socket on the logic board.
      FixBotに聞いてみる
      コメントを追加
    1. Flip MinoHD Display Screen Replacement, Display Screen: 手順 3、 3の画像 1 Flip MinoHD Display Screen Replacement, Display Screen: 手順 3、 3の画像 2 Flip MinoHD Display Screen Replacement, Display Screen: 手順 3、 3の画像 3
      この手順で使用する道具:
      • Using tweezers, pull connecting strip away from its socket on the logic board.
      • With the plastic opening tool, take the display screen out of its socket by gently lifting each corner. Flip the screen up towards the logic board that it is still connected to.
      • With the spudger, gently lift the film underneath the display bracket and peel away. Set aside.
      • With the plastic opening tool, gently pry open metal display bracket to remove from logic board.
      • Using fingernail, pry black tape up from zif socket to remove the partially attached display screen.
      FixBotに聞いてみる
      コメントを追加
    2. Flip MinoHD Display Screen Replacement: 手順 4、 1の画像 1
      • Now your display screen is liberated and ready to replace. To install a new one, follow these steps backwards.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Abigail Buckenberger
メンバー登録日: 01/06/16
732 ポイント
5のガイドは作成済み
チーム
Eastern Washington University, Team 2-1, Andersen Winter 2016 Eastern Washington University, Team 2-1, Andersen Winter 2016人のメンバー
EWU-ANDERSEN-W16S2G1
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 31
今までの合計 1,582
