メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Fellowes T7CM Trigger Sensor Replacement
必要な工具と部品
    1. Fellowes T7CM Trigger Sensor Replacement, Fellowes T7CM Casing and Trigger Replacement: 手順 1、 1の画像 1
      • Check to make sure the shredder is not plugged in to any electrical outlet.
      • Remove the shredder from the catch basket and place the silver side down on a flat surface.
      • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
      FixBotに聞いてみる
      コメントを追加
    2. Fellowes T7CM Trigger Sensor Replacement: 手順 2、 1の画像 1
      • Flip the shredder silver side down and place on a flat even surface.
      • Remove the manufacturer's label in order to gain access to the hidden screw hole.
      • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
      FixBotに聞いてみる
      コメントを追加
    3. Fellowes T7CM Trigger Sensor Replacement: 手順 3、 1の画像 1
      • Once all of the screws are removed, slowly pull apart the casing.
      • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
      • Use Caution during this procedure to prevent from damaging any of the internal parts.
      FixBotに聞いてみる
      コメントを追加
    4. Fellowes T7CM Trigger Sensor Replacement: 手順 4、 1の画像 1
      • Open the casing as shown to prevent tangling or damaging the wires.
      • Take note to how the trigger assembly is attached before removal.
      • The trigger assembly is one part and should come off all together with little to no force applied.
      • Remove the trigger assembly.
      FixBotに聞いてみる
      コメントを追加
    1. Fellowes T7CM Trigger Sensor Replacement, Main Power Cord: 手順 5、 2の画像 1 Fellowes T7CM Trigger Sensor Replacement, Main Power Cord: 手順 5、 2の画像 2
      • Remove the wire holder. This is a small screwed in piece of plastic which holds the wires in place. The screw length is 10 mm and the head diameter is 6 mm.
      FixBotに聞いてみる
      コメントを追加
    2. Fellowes T7CM Trigger Sensor Replacement: 手順 6、 1の画像 1
      • Remove the blade housing from the external case.
      • Remove the three screws from the blade housing. The screw length is 18 mm and the head diameter is 5 mm
      FixBotに聞いてみる
      コメントを追加
    3. Fellowes T7CM Trigger Sensor Replacement: 手順 7、 1の画像 1
      • Use Caution when lifting the blade housing from the casing.
      • Warning: Sharp Objects are now exposed.
      • Place the blade housing close to the case to ensure no damage occurs to the connected wires and that they remained attached to the casing.
      FixBotに聞いてみる
      コメントを追加
    4. Fellowes T7CM Trigger Sensor Replacement: 手順 8、 1の画像 1
      • Locate the main power cord.
      • Clip the wire and strip the remaining end of the wire. Twist the new cord together with the remaining old wire.
      • Use electrical tape in order to cover the wire splice.
      FixBotに聞いてみる
      コメントを追加
    1. Fellowes T7CM Trigger Sensor Replacement, Trigger Sensor: 手順 9、 2の画像 1 Fellowes T7CM Trigger Sensor Replacement, Trigger Sensor: 手順 9、 2の画像 2
      • Remove the screws holding the feeding sensor in place. The screw length is 10 mm and the head diameter is 6 mm.
      • Lift and remove the sensor.
      • Replace the faulty sensor with a new sensor.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Michael Aldrich
メンバー登録日: 10/12/16
686 ポイント
5のガイドは作成済み
チーム
IUPUI, Team 2-2, Baechle Fall 2016 IUPUI, Team 2-2, Baechle Fall 2016人のメンバー
IUPUI-BAECHLE-F16S2G2
4 メンバー
16のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 21
過去 30 日: 69
今までの合計 7,981
