メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Fellowes T7CM Shaft Replacement
必要な工具と部品
    1. Fellowes T7CM Shaft Replacement, Fellowes T7CM Casing and Trigger Replacement: 手順 1、 1の画像 1
      • Check to make sure the shredder is not plugged in to any electrical outlet.
      • Remove the shredder from the catch basket and place the silver side down on a flat surface.
      • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
      FixBotに聞いてみる
      コメントを追加
    2. Fellowes T7CM Shaft Replacement: 手順 2、 1の画像 1
      • Flip the shredder silver side down and place on a flat even surface.
      • Remove the manufacturer's label in order to gain access to the hidden screw hole.
      • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
      FixBotに聞いてみる
      コメントを追加
    3. Fellowes T7CM Shaft Replacement: 手順 3、 1の画像 1
      • Once all of the screws are removed, slowly pull apart the casing.
      • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
      • Use Caution during this procedure to prevent from damaging any of the internal parts.
      FixBotに聞いてみる
      コメントを追加
    4. Fellowes T7CM Shaft Replacement: 手順 4、 1の画像 1
      • Open the casing as shown to prevent tangling or damaging the wires.
      • Take note to how the trigger assembly is attached before removal.
      • The trigger assembly is one part and should come off all together with little to no force applied.
      • Remove the trigger assembly.
      FixBotに聞いてみる
      コメントを追加
    1. Fellowes T7CM Shaft Replacement, Gear and Shaft: 手順 5、 2の画像 1 Fellowes T7CM Shaft Replacement, Gear and Shaft: 手順 5、 2の画像 2
      • Remove the three screws holding the internal case to the external case. The screw length is 18 mm and the head diameter is 5 mm.
      • Remove the internal case.
      FixBotに聞いてみる
      コメントを追加
    2. Fellowes T7CM Shaft Replacement: 手順 6、 1の画像 1
      • Remove the feeding sensor by unscrewing the single screw holding it. The screw length is 10 mm and the head diameter is 6 mm.
      • This step may be unnecessary, but it will prevent the sensor from being damaged.
      FixBotに聞いてみる
      コメントを追加
    3. Fellowes T7CM Shaft Replacement: 手順 7、 2の画像 1 Fellowes T7CM Shaft Replacement: 手順 7、 2の画像 2
      • Remove the six screws on the gearbox.
      • Remove the gearbox cover to expose the gears.
      • The screw length is 34 mm and the head diameter is 7 mm.
      • The screw length is 26 mm and the head diameter is 7 mm.
      FixBotに聞いてみる
      コメントを追加
    4. Fellowes T7CM Shaft Replacement: 手順 8、 3の画像 1 Fellowes T7CM Shaft Replacement: 手順 8、 3の画像 2 Fellowes T7CM Shaft Replacement: 手順 8、 3の画像 3
      • Remove the gears.
      • The larger gear located in the middle may require a screwdriver to pry off.
      • Remove the gear holder by unscrewing two screws that are holding it in place. The screw length is 14 mm and the head diameter is 5 mm.
      FixBotに聞いてみる
      コメントを追加
    5. Fellowes T7CM Shaft Replacement: 手順 9、 2の画像 1 Fellowes T7CM Shaft Replacement: 手順 9、 2の画像 2
      • Remove the pin in order to pull the casing off of the shafts.
      • Remove the casing in order to expose shafts.
      FixBotに聞いてみる
      コメントを追加
    1. Fellowes T7CM Shaft Replacement, Shaft: 手順 10、 1の画像 1
      • Remove the metal attachment that holds the two shafts together.
      FixBotに聞いてみる
      コメントを追加
    2. Fellowes T7CM Shaft Replacement: 手順 11、 1の画像 1
      • The shafts can now be pulled apart and any obstructions located between or on each of the shafts can be removed.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Michael Aldrich
メンバー登録日: 10/12/16
686 ポイント
5のガイドは作成済み
チーム
IUPUI, Team 2-2, Baechle Fall 2016 IUPUI, Team 2-2, Baechle Fall 2016人のメンバー
IUPUI-BAECHLE-F16S2G2
4 メンバー
16のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 31
今までの合計 1,736
