メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Fellowes T7CM On, Off, Reverse Switch Replacement
必要な工具と部品
  1. Fellowes T7CM On,  Off, Reverse Switch Replacement, Fellowes T7CM Casing and Trigger Replacement: 手順 1、 1の画像 1
    • Check to make sure the shredder is not plugged in to any electrical outlet.
    • Remove the shredder from the catch basket and place the silver side down on a flat surface.
    • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
    FixBotに聞いてみる
    コメントを追加
  2. Fellowes T7CM On,  Off, Reverse Switch Replacement: 手順 2、 1の画像 1
    • Flip the shredder silver side down and place on a flat even surface.
    • Remove the manufacturer's label in order to gain access to the hidden screw hole.
    • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
    FixBotに聞いてみる
    コメントを追加
  3. Fellowes T7CM On,  Off, Reverse Switch Replacement: 手順 3、 1の画像 1
    • Once all of the screws are removed, slowly pull apart the casing.
    • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
    • Use Caution during this procedure to prevent from damaging any of the internal parts.
    FixBotに聞いてみる
    コメントを追加
  4. Fellowes T7CM On,  Off, Reverse Switch Replacement: 手順 4、 1の画像 1
    • Open the casing as shown to prevent tangling or damaging the wires.
    • Take note to how the trigger assembly is attached before removal.
    • The trigger assembly is one part and should come off all together with little to no force applied.
    • Remove the trigger assembly.
    FixBotに聞いてみる
    コメントを追加
  5. Fellowes T7CM On,  Off, Reverse Switch Replacement, On,  Off, Reverse Switch: 手順 5、 1の画像 1
    • Unscrew both of the screws from the circuit board of the switch . Lift the circuit board away from the device. The screw length is 10 mm and the head diameter is 6 mm.
    FixBotに聞いてみる
    コメントを追加
  6. Fellowes T7CM On,  Off, Reverse Switch Replacement: 手順 6、 2の画像 1 Fellowes T7CM On,  Off, Reverse Switch Replacement: 手順 6、 2の画像 2
    • Remove the plastic switch case.
    • After the plastic case is removed, the switch can be replaced.
    • During the switch replacement, be careful of the springs that are held in side. They can potentially come loose and get lost.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Michael Aldrich
メンバー登録日: 10/12/16
686 ポイント
5のガイドは作成済み
チーム
IUPUI, Team 2-2, Baechle Fall 2016 IUPUI, Team 2-2, Baechle Fall 2016人のメンバー
IUPUI-BAECHLE-F16S2G2
4 メンバー
16のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 64
今までの合計 4,464
