メインコンテンツにスキップ
Fan Removal
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. Fan Removal, Uncover the back panel screws: 手順 1、 2の画像 1 Fan Removal, Uncover the back panel screws: 手順 1、 2の画像 2
    • Before you begin, completely power down and unplug all cables from your console.
    • Two stickers cover the back panel screws. You can remove the stickers without heating them, though it makes them much easier to remove cleanly.
    • Heat an iOpener and lay it on the smaller sticker near the bottom of the back panel for two minutes.
    • Alternatively, you can use a hair dryer to heat the sticker.
  2. Fan Removal: 手順 2、 3の画像 1 Fan Removal: 手順 2、 3の画像 2 Fan Removal: 手順 2、 3の画像 3
    • Use a pair of angled tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  3. Fan Removal: 手順 3、 3の画像 1 Fan Removal: 手順 3、 3の画像 2 Fan Removal: 手順 3、 3の画像 3
    • Use an iOpener or hair dryer to heat the larger sticker near the center of the back panel.
  4. Fan Removal: 手順 4、 3の画像 1 Fan Removal: 手順 4、 3の画像 2 Fan Removal: 手順 4、 3の画像 3
    • Use the flat end of a spudger to scrape up a corner of the larger sticker until you can grip it with a pair of blunt tweezers.
    • Use blunt tweezers to peel back the sticker to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  5. Fan Removal, Remove the back panel screws: 手順 5、 2の画像 1 Fan Removal, Remove the back panel screws: 手順 5、 2の画像 2
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
  6. Fan Removal, Unclip the back panel: 手順 6、 3の画像 1 Fan Removal, Unclip the back panel: 手順 6、 3の画像 2 Fan Removal, Unclip the back panel: 手順 6、 3の画像 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  7. Fan Removal: 手順 7、 3の画像 1 Fan Removal: 手順 7、 3の画像 2 Fan Removal: 手順 7、 3の画像 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  8. Fan Removal, Remove the back panel: 手順 8、 3の画像 1 Fan Removal, Remove the back panel: 手順 8、 3の画像 2 Fan Removal, Remove the back panel: 手順 8、 3の画像 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  9. Fan Removal: 手順 9、 3の画像 1 Fan Removal: 手順 9、 3の画像 2 Fan Removal: 手順 9、 3の画像 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  10. Fan Removal, Remove the fan screws: 手順 10、 2の画像 1 Fan Removal, Remove the fan screws: 手順 10、 2の画像 2
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.3 mm‑long pancake screw
    • Two 9 mm‑long screws
  11. Fan Removal, Disconnect the fan cable: 手順 11、 3の画像 1 Fan Removal, Disconnect the fan cable: 手順 11、 3の画像 2 Fan Removal, Disconnect the fan cable: 手順 11、 3の画像 3
    • Use your fingernails or a pair of angled tweezers to firmly grip the edges of the fan cable connector.
    • Grip your tweezers close the connector to get a better grip.
    • Pull the connector straight out of the socket to disconnect it.
    • If you're having trouble, gently rock the connector side to side to loosen it.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  12. Fan Removal, Remove the fan: 手順 12、 3の画像 1 Fan Removal, Remove the fan: 手順 12、 3の画像 2 Fan Removal, Remove the fan: 手順 12、 3の画像 3
    この手順で使用する道具:
    Dust Blower
    $18.99
    • Slide the fan out of its slot to remove it.
    • During reassembly:
    • Before installing the fan, make sure it's clean! Use a dust blower or compressed air to blow off any dust or debris, and wipe the fan clean with a clean cloth.
    • Use a finger to keep the fan blades steady—it makes them easier to clean.
    • Note that the fan can only be installed one way—make sure Master Chief is facing you.
ゴール
Spencer Day
メンバー登録日: 09/14/22
94,893 ポイント
662のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,450のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 22
過去 30 日: 28
今までの合計 72
