メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ExoPC Slate CPU Fan Replacement
必要な工具と部品
  1. ExoPC Slate CPU Fan Replacement, Back Cover and Shield: 手順 1、 2の画像 1 ExoPC Slate CPU Fan Replacement, Back Cover and Shield: 手順 1、 2の画像 2
    • Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
    FixBotに聞いてみる
    コメントを追加
  2. ExoPC Slate CPU Fan Replacement: 手順 2、 2の画像 1 ExoPC Slate CPU Fan Replacement: 手順 2、 2の画像 2
    • Using the 00 Phillips screwdriver remove the two screws in the corners.
    • Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
    • When removing the back cover make sure that the ribbon connectors going to the screen are not damaged. Carefully fold over the cover like a book.
    FixBotに聞いてみる
    コメントを追加
  3. ExoPC Slate CPU Fan Replacement: 手順 3、 3の画像 1 ExoPC Slate CPU Fan Replacement: 手順 3、 3の画像 2 ExoPC Slate CPU Fan Replacement: 手順 3、 3の画像 3
    • Remove the tape covering the metal shield.
    • Remove the 12 screws using the Phillips #00 screwdriver.
    • Dislodge the shield by pulling the prongs away from underneath the battery. The shield should come completely off.
    FixBotに聞いてみる
    コメントを追加
  4. ExoPC Slate CPU Fan Replacement, CPU Fan: 手順 4、 2の画像 1 ExoPC Slate CPU Fan Replacement, CPU Fan: 手順 4、 2の画像 2
    • Remove the yellow tape securing the wires to the PCB board as well as the silver/grey tape.
    • Unscrew the six Phillips #00 screws.
    FixBotに聞いてみる
    コメントを追加
  5. ExoPC Slate CPU Fan Replacement: 手順 5、 2の画像 1 ExoPC Slate CPU Fan Replacement: 手順 5、 2の画像 2
    この手順で使用する道具:
    • Using tweezers, disconnect the connector in the top left.
    • Pull the fan heat sink away from the PC.
    • Remove the fan from the copper heat sink with the tweezers by releasing the metal clips.
    • Apply a sparing amount of thermal paste to each chip.
    • Attach the new or cleaned fan to the heat sink using the metal clips. Line up the heat sink with the screw holes and press down firmly to spread out the thermal paste.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Jonathon Cronin
メンバー登録日: 10/29/18
337 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G1, Peak Fall 2018 UMass Dartmouth, Team S2-G1, Peak Fall 2018人のメンバー
UMASSD-PEAK-F18S2G1
3 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 23
今までの合計 592
