はじめに
One of the most common issues that plagues tablets and other mobile devices is that their battery degrades overtime. This results in the device being unable to hold a charge. In this case, replacing the battery is the best option.
必要な工具と部品
Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
Using the 00 Phillips screwdriver remove the two screws in the corners.
Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
