メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Evercade EXP Directional Pad Replacement
必要な工具と部品
  1. Evercade EXP Directional Pad Replacement, Faceplate: 手順 1、 3の画像 1 Evercade EXP Directional Pad Replacement, Faceplate: 手順 1、 3の画像 2 Evercade EXP Directional Pad Replacement, Faceplate: 手順 1、 3の画像 3
    • Lay the device on a flat surface, with the screen facing the sufrace.
    • Using angled tweezers, remove the six rubber screw covers from the sockets.
    • The covers are all identical, so they do not need to be stored separately from one another.
    FixBotに聞いてみる
    コメントを追加
  2. Evercade EXP Directional Pad Replacement: 手順 2、 3の画像 1 Evercade EXP Directional Pad Replacement: 手順 2、 3の画像 2 Evercade EXP Directional Pad Replacement: 手順 2、 3の画像 3
    • Using a Phillips #00 screwdriver, remove the six 8 mm screws on the lower case.
    FixBotに聞いてみる
    コメントを追加
  3. Evercade EXP Directional Pad Replacement: 手順 3、 2の画像 1 Evercade EXP Directional Pad Replacement: 手順 3、 2の画像 2
    • Flip the device so the screen is facing you.
    • Four hidden retaining clips hold the pieces together even near each corner of the screen.
    • Insert a Jimmy into the seam located between the faceplate and the shell.
    • Move the a Jimmy toward the screen until you find the first clasp. Move the handle of the jimmy tool up to pop the faceplate free from the clasp.
    • Repeat until for each of the four clasps to fully release the faceplate from the shell.
    • Do not use excessive force when moving the Jimmy. The plastic may shear if too much force is applied horizontally, and it may snap if too much vertical force is applied.
    FixBotに聞いてみる
    コメントを追加
  4. Evercade EXP Directional Pad Replacement: 手順 4、 3の画像 1 Evercade EXP Directional Pad Replacement: 手順 4、 3の画像 2 Evercade EXP Directional Pad Replacement: 手順 4、 3の画像 3
    • Flip the faceplate away from the shell carefully. The faceplate is still connected to the motherboard via a ribbon cable.
    • Flip up the locking flap securing the display ribbon cable, then use tweezers to disconnect the ribbon cable.
    • Be careful when separating the faceplate from the shell, the buttons are held in place by the connection, so they may fall out when opening the device.
    FixBotに聞いてみる
    コメントを追加
  5. Evercade EXP Directional Pad Replacement, Buttons: 手順 5、 3の画像 1 Evercade EXP Directional Pad Replacement, Buttons: 手順 5、 3の画像 2 Evercade EXP Directional Pad Replacement, Buttons: 手順 5、 3の画像 3
    • Locate the four circular buttons in a diamond shape on the face plate, the two circular buttons placed next to each other, and the two small oval buttons and a circular button in a row near those in a diamond pattern.
    • Using angled tweezer, gently remove the buttons from the face plate. The buttons may fall out, so be ready to catch any that fall from the device before intended removal.
    • The buttons are held in place with the pressure of the shell and faceplate when closed. They should be removed with a nominal amount of force.
    FixBotに聞いてみる
    コメントを追加
  6. Evercade EXP Directional Pad Replacement, Directional Pad: 手順 6、 2の画像 1 Evercade EXP Directional Pad Replacement, Directional Pad: 手順 6、 2の画像 2
    • The directional pad is composed of two pieces, the back of the button holds the face of the button within a small square hole. The pieces are held together by friction, and do not require very much force to seperate.
    • Using tweezers, pull the face of the directional pad from its socket in the back piece until the two separate.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Michael Williams
メンバー登録日: 02/03/26
356 ポイント
3のガイドは作成済み
チーム
Utah Tech University, Team 1-6, McMurrin Spring 2026 Utah Tech University, Team 1-6, McMurrin Spring 2026人のメンバー
UTAHTECH-MCMURRIN-S26S1G6
3 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 42
今までの合計 80
