メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Eton FRX3 Volume Dial Replacement
必要な工具と部品
  1. Eton FRX3 Volume Dial Replacement, Rechargeable Battery Pack: 手順 1、 1の画像 1
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
    FixBotに聞いてみる
    コメントを追加
  2. Eton FRX3 Volume Dial Replacement: 手順 2、 1の画像 1
    • Disconnect the battery pack wires from the device and remove the battery pack.
    FixBotに聞いてみる
    コメントを追加
  3. Eton FRX3 Volume Dial Replacement, Case Assembly: 手順 3、 1の画像 1
    • On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
    FixBotに聞いてみる
    コメントを追加
  4. Eton FRX3 Volume Dial Replacement: 手順 4、 1の画像 1
    • While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
    FixBotに聞いてみる
    コメントを追加
  5. Eton FRX3 Volume Dial Replacement: 手順 5、 1の画像 1
    • Remove the two Phillips #00 screws located in the center of the back of the device.
    • You will need to use a thin shafted screwdriver or a female hexagonal bit that is found in the iFixit 54 bit toolkit to extend the reach of the Phillips #00 bit.
    FixBotに聞いてみる
    コメントを追加
  6. Eton FRX3 Volume Dial Replacement: 手順 6、 1の画像 1
    • On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
    • Try to keep the adhesive on the rubber feet as clean as possible to insure that they can be reattached during reassembly.
    FixBotに聞いてみる
    コメントを追加
  7. Eton FRX3 Volume Dial Replacement: 手順 7、 1の画像 1
    • Pull the two halves of the device's case apart.
    • Take care when pulling the two halves apart. There are three cables that connect components of the device to the motherboard. Disconnect these cables in order to separate the two halves of the device's case.
    FixBotに聞いてみる
    コメントを追加
  8. Eton FRX3 Volume Dial Replacement, Volume Dial: 手順 8、 1の画像 1
    • Unplug the socket connection from the I/O board as shown in the image.
    FixBotに聞いてみる
    コメントを追加
  9. Eton FRX3 Volume Dial Replacement: 手順 9、 1の画像 1
    • Remove the two 1 cm Philips #0 screws that secure the tuning dial panel to the device case.
    FixBotに聞いてみる
    コメントを追加
  10. Eton FRX3 Volume Dial Replacement: 手順 10、 1の画像 1
    • Gently lift the dial upwards to remove it.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Jose Mendieta
メンバー登録日: 02/10/16
255 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 1-6, Nance Spring 2016 USF Tampa, Team 1-6, Nance Spring 2016人のメンバー
USFT-NANCE-S16S1G6
4 メンバー
26のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 32
今までの合計 889
