メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Epson PPC650 Screen Replacement
必要な工具と部品
    1. Epson PPC650 Screen Replacement, Case: 手順 1、 3の画像 1 Epson PPC650 Screen Replacement, Case: 手順 1、 3の画像 2 Epson PPC650 Screen Replacement, Case: 手順 1、 3の画像 3
      • Locate the silver power button. Gently slide the button to the middle section labeled "off" to shut down the camera.
      • Remove the batteries from the battery compartment located on the underside of the camera.
      • Remove the SD card from the compartment located on the flat, left side of the camera.
      FixBotに聞いてみる
      コメントを追加
    2. Epson PPC650 Screen Replacement: 手順 2、 1の画像 1
      • Remove the two screws on the rounded side of the camera.
      FixBotに聞いてみる
      コメントを追加
    3. Epson PPC650 Screen Replacement: 手順 3、 2の画像 1 Epson PPC650 Screen Replacement: 手順 3、 2の画像 2
      • Remove the three screws on the flat side of the camera.
      • All of the silver screws go into the side of the camera that is silver.
      • All of the black screws go into the side of the camera that is black.
      FixBotに聞いてみる
      コメントを追加
    4. Epson PPC650 Screen Replacement: 手順 4、 1の画像 1
      • Remove the four screws from the bottom of the camera.
      FixBotに聞いてみる
      コメントを追加
    5. Epson PPC650 Screen Replacement: 手順 5、 3の画像 1 Epson PPC650 Screen Replacement: 手順 5、 3の画像 2 Epson PPC650 Screen Replacement: 手順 5、 3の画像 3
      • Separate the front and the back pieces of the camera's plastic casing using a spudger.
      • WARNING: When pulling the front plastic casing, be careful of the wires that are connected to the aperture control.
      • Use minimal force so that the plastic casing does not break.
      • When separating the small silver siding, the indicator for the view/off/playback may fall out.
      • The plastic viewing window located on the top of the camera may also become lose and fall out.
      FixBotに聞いてみる
      コメントを追加
    1. Epson PPC650 Screen Replacement, Screen: 手順 6、 3の画像 1 Epson PPC650 Screen Replacement, Screen: 手順 6、 3の画像 2 Epson PPC650 Screen Replacement, Screen: 手順 6、 3の画像 3
      • Remove the copper sheet from the front and back paneling.
      • Use the spudger to unsolder the copper paneling.
      • Use the spudger to separate the back circuit board from the camera.
      FixBotに聞いてみる
      コメントを追加
    2. Epson PPC650 Screen Replacement: 手順 7、 2の画像 1 Epson PPC650 Screen Replacement: 手順 7、 2の画像 2
      • The picture viewing screen is glued to the backing as well as wired in with pink and white wires.
      • Exert minimal force to pull the screen loose from the camera.
      • Remove the pink and white wiring from the internal paneling. These wires are soldered in.
      • Remove the orange data hookup cable that feeds into the back circuit board.
      FixBotに聞いてみる
      コメントを追加
      • Once all wires have been detached and the old screen has been removed place the new screen into the camera.
      • Insert data hookup into the back of the camera and into the new screen.
      • Re-solder the new pink and white wire onto the internal circuit board.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
7人の作成者と共同で作成されました。
Anne
メンバー登録日: 02/12/13
107 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-5, Buehl Spring 2013 Ohio State, Team 1-5, Buehl Spring 2013人のメンバー
OSU-BUEHL-S13S1G5
4 メンバー
24のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 24
今までの合計 803
