メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Ematic Genesis Camera Replacement
必要な工具と部品
  1. Ematic Genesis Camera Replacement, Ematic Genesis Casing: 手順 1、 3の画像 1 Ematic Genesis Camera Replacement, Ematic Genesis Casing: 手順 1、 3の画像 2 Ematic Genesis Camera Replacement, Ematic Genesis Casing: 手順 1、 3の画像 3
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
    FixBotに聞いてみる
    コメントを追加
  2. Ematic Genesis Camera Replacement: 手順 2、 3の画像 1 Ematic Genesis Camera Replacement: 手順 2、 3の画像 2 Ematic Genesis Camera Replacement: 手順 2、 3の画像 3
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
    FixBotに聞いてみる
    コメントを追加
  3. Ematic Genesis Camera Replacement: 手順 3、 1の画像 1
    • Remove back plate from screen plate and lay both down flat next to each other.
    FixBotに聞いてみる
    コメントを追加
  4. Ematic Genesis Camera Replacement, Camera: 手順 4、 2の画像 1 Ematic Genesis Camera Replacement, Camera: 手順 4、 2の画像 2
    • Once the panels are separated, remove the tape holding down the ribbon connector that is connecting the camera to the motherboard.
    FixBotに聞いてみる
    コメントを追加
  5. Ematic Genesis Camera Replacement: 手順 5、 2の画像 1 Ematic Genesis Camera Replacement: 手順 5、 2の画像 2
    • Lift up the black lever of the connector that holds the camera ribbon in place.
    FixBotに聞いてみる
    コメントを追加
  6. Ematic Genesis Camera Replacement: 手順 6、 2の画像 1 Ematic Genesis Camera Replacement: 手順 6、 2の画像 2
    • Gently pull the ribbon out of the connector and lift the camera out of the casing.
    • There is adhesive holding the camera in the case. Pull up strong enough to separate the camera from the casing without damaging the components.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Justin Rohrman
メンバー登録日: 03/23/15
745 ポイント
6のガイドは作成済み
チーム
Baylor, Team 4-3, Williams Spring 2015 Baylor, Team 4-3, Williams Spring 2015人のメンバー
BU-WILLIAMS-S15S4G3
3 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 37
今までの合計 452
