メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Ematic EGQ307 LCD Replacement
必要な工具と部品
    1. Ematic EGQ307 LCD Replacement, LCD: 手順 1、 1の画像 1
      • There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
      FixBotに聞いてみる
      コメントを追加
    2. Ematic EGQ307 LCD Replacement: 手順 2、 2の画像 1 Ematic EGQ307 LCD Replacement: 手順 2、 2の画像 2
      • Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
      • Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
      FixBotに聞いてみる
      コメントを追加
    3. Ematic EGQ307 LCD Replacement: 手順 3、 3の画像 1 Ematic EGQ307 LCD Replacement: 手順 3、 3の画像 2 Ematic EGQ307 LCD Replacement: 手順 3、 3の画像 3
      この手順で使用する道具:
      Plastic Cards
      $2.99
      • Once you pry off the plastic backing, you will expose the battery and the motherboard.
      • Remove the tape holding the battery to the plastic frame. The battery is glued to the back of the LCD.
      • Pry the battery off the LCD using a flat and rigid piece of plastic, such as the plastic card.
      FixBotに聞いてみる
      コメントを追加
    4. Ematic EGQ307 LCD Replacement: 手順 4、 3の画像 1 Ematic EGQ307 LCD Replacement: 手順 4、 3の画像 2 Ematic EGQ307 LCD Replacement: 手順 4、 3の画像 3
      • Remove the three 2mm x 0.5mm screws with a Phillips #0 Screwdriver head from the motherboard.
      • Carefully remove the motherboard from the LCD backing. Remove tape from the edges of the LCD.
      • Carefully pry off the LCD with the spudger.
      • Carefully remove the motherboard, battery, and the speaker, so wires do not get disconnected.
      FixBotに聞いてみる
      コメントを追加
    5. Ematic EGQ307 LCD Replacement: 手順 5、 3の画像 1 Ematic EGQ307 LCD Replacement: 手順 5、 3の画像 2 Ematic EGQ307 LCD Replacement: 手順 5、 3の画像 3
      • Now LCD is removed and is ready to be replaced.
      FixBotに聞いてみる
      コメントを追加
終わりに
To reassemble your device, follow these instructions in reverse order, note you will need to solder for this replacement.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Jonathan Scinto
メンバー登録日: 07/21/15
530 ポイント
4のガイドは作成済み
チーム
Eastern Washington University, Team 1-1, Rowley SU 2015 Eastern Washington University, Team 1-1, Rowley SU 2015人のメンバー
EWU-ROWLEY-SU15S1G1
4 メンバー
25のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 38
今までの合計 1,552
