メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Ematic EGQ307 Digitizer Replacement
必要な工具と部品
    1. Ematic EGQ307 Digitizer Replacement, Digitizer: 手順 1、 2の画像 1 Ematic EGQ307 Digitizer Replacement, Digitizer: 手順 1、 2の画像 2
      • There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
      FixBotに聞いてみる
      コメントを追加
    2. Ematic EGQ307 Digitizer Replacement: 手順 2、 2の画像 1 Ematic EGQ307 Digitizer Replacement: 手順 2、 2の画像 2
      • Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
      • Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
      FixBotに聞いてみる
      コメントを追加
    3. Ematic EGQ307 Digitizer Replacement: 手順 3、 3の画像 1 Ematic EGQ307 Digitizer Replacement: 手順 3、 3の画像 2 Ematic EGQ307 Digitizer Replacement: 手順 3、 3の画像 3
      この手順で使用する道具:
      Plastic Cards
      $2.99
      • Once you pry off the plastic backing, you will expose the battery and the motherboard.
      • Remove the tape holding the battery to the plastic frame. The battery is glued to the back of the LCD.
      • Pry the battery off the LCD using a flat and rigid piece of plastic, such as the plastic card.
      FixBotに聞いてみる
      コメントを追加
    4. Ematic EGQ307 Digitizer Replacement: 手順 4、 3の画像 1 Ematic EGQ307 Digitizer Replacement: 手順 4、 3の画像 2 Ematic EGQ307 Digitizer Replacement: 手順 4、 3の画像 3
      • Carefully remove the tape holding the camera in place as the camera is attached to the backing of the tape.
      • Gently lift up the black lever that’s holding the camera ribbon in place using a long piece of stiff plastic.
      • Now, remove the camera from the device.
      FixBotに聞いてみる
      コメントを追加
    5. Ematic EGQ307 Digitizer Replacement: 手順 5、 3の画像 1 Ematic EGQ307 Digitizer Replacement: 手順 5、 3の画像 2 Ematic EGQ307 Digitizer Replacement: 手順 5、 3の画像 3
      • Remove the three 2mm x 0.5mm screws with a Phillips #0 Screwdriver head from the motherboard.
      • Carefully remove the motherboard from the LCD backing. Remove tape from the edges of the LCD.
      • Carefully pry off the LCD with a piece of plastic.
      • Carefully remove the motherboard, battery, and the speaker, so wires do not get disconnected.
      FixBotに聞いてみる
      コメントを追加
    6. Ematic EGQ307 Digitizer Replacement: 手順 6、 3の画像 1 Ematic EGQ307 Digitizer Replacement: 手順 6、 3の画像 2 Ematic EGQ307 Digitizer Replacement: 手順 6、 3の画像 3
      • Now Protective Screen is removed and is ready to be replaced.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Jonathan Scinto
メンバー登録日: 07/21/15
530 ポイント
4のガイドは作成済み
チーム
Eastern Washington University, Team 1-1, Rowley SU 2015 Eastern Washington University, Team 1-1, Rowley SU 2015人のメンバー
EWU-ROWLEY-SU15S1G1
4 メンバー
25のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 24
今までの合計 1,305
