メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Eightarc Fusion Joystick Replacement
必要な工具と部品
  1. Eightarc Fusion Joystick Replacement, Joystick: 手順 1、 2の画像 1 Eightarc Fusion Joystick Replacement, Joystick: 手順 1、 2の画像 2
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
    FixBotに聞いてみる
    コメントを追加
  2. Eightarc Fusion Joystick Replacement: 手順 2、 1の画像 1
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
    FixBotに聞いてみる
    コメントを追加
  3. Eightarc Fusion Joystick Replacement: 手順 3、 2の画像 1 Eightarc Fusion Joystick Replacement: 手順 3、 2の画像 2
    • Use the large plastic opening tool to softly pry the lip on the white 5 pin connector to relieve pressure while pulling the 5 pin connector.
    • Remove the white connector from the microswitch assembly.
    FixBotに聞いてみる
    コメントを追加
  4. Eightarc Fusion Joystick Replacement: 手順 4、 2の画像 1 Eightarc Fusion Joystick Replacement: 手順 4、 2の画像 2
    • Insert a #4 Flat Head screwdriver into the shaft of the joystick and grasp the ball topper with your other hand.
    • Turn the flat head screwdriver counter clockwise for a quarter turn while tightly holding the ball topper.
    • The ball topper should now be loose enough to unscrew by hand.
    • Set aside the shaft cover, dust cover, and ball topper.
    FixBotに聞いてみる
    コメントを追加
  5. Eightarc Fusion Joystick Replacement: 手順 5、 2の画像 1 Eightarc Fusion Joystick Replacement: 手順 5、 2の画像 2
    • Remove the four 8.35 mm screws from the mounting plate of the joystick using a Phillips Head #2 screwdriver.
    • Remove the joystick assembly from the controller.
    FixBotに聞いてみる
    コメントを追加
  6. Eightarc Fusion Joystick Replacement: 手順 6、 3の画像 1 Eightarc Fusion Joystick Replacement: 手順 6、 3の画像 2 Eightarc Fusion Joystick Replacement: 手順 6、 3の画像 3
    • Place joystick assembly on a hard, flat surface.
    • Gently press on the four black tabs on each side of the assembly.
    • With the tabs depressed, lift the clear restrictor plate from the assembly.
    FixBotに聞いてみる
    コメントを追加
  7. Eightarc Fusion Joystick Replacement: 手順 7、 1の画像 1
    • Remove the switch housing from the assembly by lifting straight up.
    • The joystick assembly is now ready to be replaced or cleaned.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Austin
メンバー登録日: 01/28/15
245 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 17-35, Amido Winter 2015 Cal Poly, Team 17-35, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S17G35
4 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 60
今までの合計 1,379
