メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Eightarc Fusion Button Replacement
必要な工具と部品
  1. Eightarc Fusion Button Replacement, Buttons: 手順 1、 1の画像 1
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface, or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65 mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
    FixBotに聞いてみる
    コメントを追加
  2. Eightarc Fusion Button Replacement: 手順 2、 1の画像 1
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
    FixBotに聞いてみる
    コメントを追加
  3. Eightarc Fusion Button Replacement: 手順 3、 1の画像 1
    • Remove the clear rubber casing around the wire connector by lifting the casing up and moving it up along the wire.
    • Repeat for second clear rubber casing.
    FixBotに聞いてみる
    コメントを追加
  4. Eightarc Fusion Button Replacement: 手順 4、 2の画像 1 Eightarc Fusion Button Replacement: 手順 4、 2の画像 2
    • Gently grasp and lift up on the metal section of the wire to remove the wire from the button connector.
    • A slight wiggling motion might help remove the wire from the connector.
    • Make sure to keep track of which wires go to what button slot location.
    FixBotに聞いてみる
    コメントを追加
  5. Eightarc Fusion Button Replacement: 手順 5、 2の画像 1 Eightarc Fusion Button Replacement: 手順 5、 2の画像 2
    • Gently depress the two plastic tabs on both of the sides of the button casing.
    • The plastic tabs on the buttons are extremely fragile, handle with care.
    • Slightly push the button down, out of the controller until it slides out.
    • During re-assembly, make sure the button tabs align with the slots in the casing when inserting the button back in.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Austin
メンバー登録日: 01/28/15
245 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 17-35, Amido Winter 2015 Cal Poly, Team 17-35, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S17G35
4 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 27
今までの合計 1,143
