はじめに
If your Dyson V8 Animal is not performing at optimal efficiency, you may need to replace or clean the intake filter. The intake filter collects dust and other items to allow the vacuum to perform at peak efficiency. A broken or dirty filter will make the vacuum perform poorly.
Before using this guide, inspect the intake filter. Sometimes, the intake filter only needs to be washed and cleaned rather than being replaced completely.
No special skills are required for this guide.
Before beginning, make sure to turn off the vacuum and disconnect it from any external power source.
必要な工具と部品
Twist the air intake filter cap counter clock wise.
Pull the air intake filter cap away from the handle.
