メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dyson DC39 Origin Ball Wheels Replacement
必要な工具と部品
    1. Dyson DC39 Origin Ball Wheels Replacement, Bin: 手順 1、 3の画像 1 Dyson DC39 Origin Ball Wheels Replacement, Bin: 手順 1、 3の画像 2 Dyson DC39 Origin Ball Wheels Replacement, Bin: 手順 1、 3の画像 3
      • Push down on the gray button located next to the power button to release the bin from the ball housing.
      • Pull the bin away, then up from the ball housing to remove it.
      • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
      FixBotに聞いてみる
      コメントを追加
    1. Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: 手順 2、 3の画像 1 Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: 手順 2、 3の画像 2 Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: 手順 2、 3の画像 3
      • Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
      • Remove the four 18.0 mm Torx 15 screws.
      FixBotに聞いてみる
      コメントを追加
    2. Dyson DC39 Origin Ball Wheels Replacement: 手順 3、 3の画像 1 Dyson DC39 Origin Ball Wheels Replacement: 手順 3、 3の画像 2 Dyson DC39 Origin Ball Wheels Replacement: 手順 3、 3の画像 3
      • Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
      • Hold the steering assembly base near one of the wheels.
      • Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
      • Push up on the steering assembly to remove it completely from the ball housing.
      • During reassembly, slide the steering assembly in first, then push the pin back into its locking position.
      FixBotに聞いてみる
      コメントを追加
    1. Dyson DC39 Origin Ball Wheels Replacement, Ball Wheels: 手順 4、 2の画像 1 Dyson DC39 Origin Ball Wheels Replacement, Ball Wheels: 手順 4、 2の画像 2
      • Remove the 21.4 mm Torx 15 screw located at the center of the ball wheel.
      • There is one screw located at the center of each wheel.
      FixBotに聞いてみる
      コメントを追加
    2. Dyson DC39 Origin Ball Wheels Replacement: 手順 5、 3の画像 1 Dyson DC39 Origin Ball Wheels Replacement: 手順 5、 3の画像 2 Dyson DC39 Origin Ball Wheels Replacement: 手順 5、 3の画像 3
      • Pull the wheel away from the main body of the device.
      • This may require a lot of force. The plastic wheel may bend slightly.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Michael Hutcheson
メンバー登録日: 04/26/17
312 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S23-G6, Livingston Spring 2017 Cal Poly, Team S23-G6, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S23G6
3 メンバー
24のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 36
今までの合計 2,673
