メインコンテンツにスキップ
DualShock 3リアカバーの交換
必要な工具と部品
  1. DualShock 3リアカバーの交換, リアカバー: 手順 1、 1の画像 1
    • リアカバーをコントローラに固定している5本の7.2 mmのプラスネジを取り外します。
    I have 2 controllers I'd like to fix, and both have at least one stripped screw in them. Any tips for removing them?
    Joe - 返信
    For me the PH #0 had too much play. I ended up using the PH #1 which was a perfect fit.
    Yokocapolo - 返信
  2. DualShock 3リアカバーの交換: 手順 2、 1の画像 1
    • アナログスティックの間にあるリアカバーを押し、その下端をコントローラーの残りの部分からわずかに持ち上げます。
    Es ist nicht ganz eindeutig das zwischen den beiden Analog-Sticks gedrückt werden muss. Der gelbe Punkt fällt kaum auf. Ein Bild mit Daumen an dieser Stelle wäre gut oder soooo…
    Tom - 返信
    it’s not very clear but for this step you need to push where the yellow dot is shown on the picture. it’s rather tough. you kind of have to move the whole back plate a bit for it to work.
    Brandon der Blatter - 返信
    I’m stuck at this step because I can’t for the life of me undo the clip
    IttyBittyGamerVR - 返信
    Yeah I’m lost here too. I’m pushing where the dot is but nothing is happening. What am I trying to accomplish by pushing there? Is there a clasp on the inside I’m trying to undo or something? I really don’t want to break the controller by using too much force or opening it the wrong way.
    Could it be that the sixaxis I have is constructed differently? Or is this just a difficult step?
    Joe - 返信
    Adding: I ended up getting the shell off but ended up breaking off a small piece which I'm guessing was securing the front and back shells together. The trigger buttons and pieces remained intact on one of my two controllers which is what I was worried about, though I did have to fit the small trigger pieces back in.
    The one controller seemed to fit back together just fine without the small piece that broke off, and buttons seemed to feel and work fine too.
    Joe -
    I had to use a small flathead to lever it apart.
    mbelanger - 返信
  3. DualShock 3リアカバーの交換: 手順 3、 2の画像 1 DualShock 3リアカバーの交換: 手順 3、 2の画像 2
    • リアカバーをコントローラーの上端に向かって少し押して、2番目のトリガーのフロントエッジを出します。
    • 2番目のトリガーが飛び出さないように、コントローラーの残りの部分から背面カバーを引き離してください。
    • アクシデントでトリガーボタンが飛び出た場合、トリガーボタンを再装着する手順を参照してください。
    the "trigger button guide" link links back to this page :o
    Alexander McMahon - 返信
    I accidentally popped a trigger off, and both L1 and R1, because I skimmed and didn't read this step. Fortunately it's not hard. The tricky part with the triggers is that there's a little spring on them. You have to press the side of the spring that's pointing away from the trigger against the sloped surface of the controller (look at the other trigger for reference, if you only popped one off). Then you just slide the trigger on until the "handlebar" bits near the center click into place.
    briancaraher - 返信
    The reset button – a small mostly-rectangular rubberized piece – fell out as I removed the rear cover. It covers the hole near the middle screw and has a post that presses SW1 on the motherboard.
    Fletcher Stern - 返信
終わりに
デバイスを再組み立てする際は、以下の手順を逆の順序で実行してください。
26 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
9人の作成者と共同で作成されました。
Andrew Bookholt
592,087 ポイント
619のガイドは作成済み
3 件のコメント
i have a different dualshock 3 than yours. mine is built in a different way and has a different battery
MasterKlaus Produtions (Swe0b) - 返信
Sony did that throughout the Dualshock 3’s production as they found out what would cause them to malfunction and fixed the issue. It should be alright as long as you are able to replace the battery when needed.
Aiodensghost -
iran:
نحوهی تعویض طلق دسته پلی سه هم بذارین. لطفان
مجید محمدی - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 32
過去 30 日: 129
今までの合計 24,867
