メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dopo Double Power 7 Digitizer Replacement
必要な工具と部品
  1. Dopo Double Power 7 Digitizer Replacement, Rear Panel: 手順 1、 1の画像 1
    • The rear panel is secured to the front case and can simply be pried apart without damage.
    FixBotに聞いてみる
    コメントを追加
  2. Dopo Double Power 7 Digitizer Replacement: 手順 2、 1の画像 1
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
    FixBotに聞いてみる
    コメントを追加
  3. Dopo Double Power 7 Digitizer Replacement: 手順 3、 1の画像 1
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
    FixBotに聞いてみる
    コメントを追加
  4. Dopo Double Power 7 Digitizer Replacement: 手順 4、 1の画像 1
    • The rear panel should come completely off.
    FixBotに聞いてみる
    コメントを追加
  5. Dopo Double Power 7 Digitizer Replacement, Camera: 手順 5、 1の画像 1
    • Remove any black static tape that may be covering the motherboard.
    FixBotに聞いてみる
    コメントを追加
  6. Dopo Double Power 7 Digitizer Replacement: 手順 6、 2の画像 1 Dopo Double Power 7 Digitizer Replacement: 手順 6、 2の画像 2
    • The camera is taped in place.
    • Use the flat end of a spudger to disconnect the front-facing camera cable from its socket on the motherboard.
    • Our cable had previously been cut but yours can be disconnected by lifting up on the black section of the socket, as shown by the arrow, and pulling the cable out.
    • Simply, pull back the tape and remove the camera.
    FixBotに聞いてみる
    コメントを追加
  7. Dopo Double Power 7 Digitizer Replacement, Digitizer: 手順 7、 2の画像 1 Dopo Double Power 7 Digitizer Replacement, Digitizer: 手順 7、 2の画像 2
    この手順で使用する道具:
    • Use a Phillips Head Screwdriver size 0.
    • Remove the four screws holding the motherboard inplace.
    • Using the flat end of a spudger or tweezers, remove the three cables connected to the motherboard.
    • The cables can be disconnected by lifting up on the black section of the socket.
    • Once the lever is lifted, pull out the cable by gently tugging on it.
    FixBotに聞いてみる
    コメントを追加
  8. Dopo Double Power 7 Digitizer Replacement: 手順 8、 1の画像 1
    • Using wire cutters, cut only the gray wire.
    FixBotに聞いてみる
    コメントを追加
  9. Dopo Double Power 7 Digitizer Replacement: 手順 9、 1の画像 1
    • Using a metal spudger, carefully pry the battery away from the digitizer.
    • Be careful not to damage the battery.
    • At this point, the battery and the motherboard will still be connected although it is not shown in the image.
    FixBotに聞いてみる
    コメントを追加
  10. Dopo Double Power 7 Digitizer Replacement: 手順 10、 1の画像 1
    • The back of the digitizer is attached along the edge by 12 plastic clips.
    FixBotに聞いてみる
    コメントを追加
  11. Dopo Double Power 7 Digitizer Replacement: 手順 11、 1の画像 1
    • The best way to remove the digitizer is to use a plastic tool and pull back the clips so that it can lift out.
    • Be gentle and be sure not to break any of the clips.
    FixBotに聞いてみる
    コメントを追加
  12. Dopo Double Power 7 Digitizer Replacement: 手順 12、 2の画像 1 Dopo Double Power 7 Digitizer Replacement: 手順 12、 2の画像 2
    • The digitizer can now be removed and replaced.
    FixBotに聞いてみる
    コメントを追加
  13. Dopo Double Power 7 Digitizer Replacement: 手順 13、 2の画像 1 Dopo Double Power 7 Digitizer Replacement: 手順 13、 2の画像 2
    • Soldering will be required to connect the new digitizer.
    • Any remaining wire left from the old digitizer will need to be removed from the motherboard.
    • Take care not to burn yourself or damage the motherboard, wires, or new digitizer while soldering.
    • Solder the new digitizer to the soldering point shown within the image.
    • Using wire strippers, strip the end of the gray wire connected to the new digitizer about a 1/8".
    • Solder the gray wire to the soldering point on the motherboard as shown within the image.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
mike pelosi
メンバー登録日: 10/30/15
682 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 1-2, Miles Fall 2015 UMass Dartmouth, Team 1-2, Miles Fall 2015人のメンバー
UMASSD-MILES-F15S1G2
4 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 22
今までの合計 884
