メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dopo Double Power 7 Battery Replacement
必要な工具と部品
  1. Dopo Double Power 7 Battery Replacement, Rear Panel: 手順 1、 1の画像 1
    • The rear panel is secured to the front case and can simply be pried apart without damage.
    FixBotに聞いてみる
    コメントを追加
  2. Dopo Double Power 7 Battery Replacement: 手順 2、 1の画像 1
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
    FixBotに聞いてみる
    コメントを追加
  3. Dopo Double Power 7 Battery Replacement: 手順 3、 1の画像 1
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
    FixBotに聞いてみる
    コメントを追加
  4. Dopo Double Power 7 Battery Replacement: 手順 4、 1の画像 1
    • The rear panel should come completely off.
    FixBotに聞いてみる
    コメントを追加
  5. Dopo Double Power 7 Battery Replacement, Battery: 手順 5、 1の画像 1
    • Cut only the red and black wires attaching the battery to the motherboard.
    • Be sure to remove any remaining wire attached to the motherboard.
    FixBotに聞いてみる
    コメントを追加
  6. Dopo Double Power 7 Battery Replacement: 手順 6、 1の画像 1
    • Using a metal spudger, carefully pry the battery away from the digitizer.
    • Be careful to not damage the battery. This could result in injury.
    FixBotに聞いてみる
    コメントを追加
  7. Dopo Double Power 7 Battery Replacement: 手順 7、 1の画像 1
    • Using wire strippers, strip the ends of the red and black wires connected to the the new battery back about a 1/8".
    • Twist the strands of the spliced wire together.
    • Using a soldering iron, apply heat to one bare wire connections you have just made.
    • When the connection is hot enough melt solder on the opposite side of the wire to the iron as shown in the image. Do not melt to much solder.
    • Once connection is made wait for it to cool off and gently pull each side of the wire to test durability.
    • Repeat this process with the other wire.
    • If you do not have access to a soldering iron, leave the old battery wires attached to the motherboard and simply splice the new battery's wires to them.
    • This video provides basic instructions for splicing wires using crimping and heat shrink technique.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
mike pelosi
メンバー登録日: 10/30/15
682 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 1-2, Miles Fall 2015 UMass Dartmouth, Team 1-2, Miles Fall 2015人のメンバー
UMASSD-MILES-F15S1G2
4 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 21
今までの合計 1,325
