メインコンテンツにスキップ
Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part
必要な工具と部品
  1. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part, Sony Cyber Shot WX80: 手順 1、 3の画像 1 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part, Sony Cyber Shot WX80: 手順 1、 3の画像 2 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part, Sony Cyber Shot WX80: 手順 1、 3の画像 3
    • Remove all six #00 screws holding the outer chassis together with a Phillips #00 screwdriver.
    • Keep track of all screws as they are small and very easy to lose
  2. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: 手順 2、 3の画像 1 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: 手順 2、 3の画像 2 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: 手順 2、 3の画像 3
    • At this point most of the parts in the camera should be free moving.
    • Take note of the small free moving flap near the battery port seen in the first of the three photos.
    • Remove the front of the shell case with the spudger. Insert the spudger into the seam on the right side of the camera and pry away from the back case.
    • Using the spudger, repeat the process to remove the back of the case. Pry away from the front of the camera.
  3. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: 手順 3、 3の画像 1 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: 手順 3、 3の画像 2 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: 手順 3、 3の画像 3
    • Turn the camera so that you are looking at the LCD screen.
    • Use tweezers to remove the first of two ribbon cables holding the LCD screen in place. Pull directly out of the port.
    • Use tweezers to remove the second of the two ribbon cables using the same method.
    • Take care not to tear the ribbons. They are the communication networks that your screen uses to operate.
    • The LCD screen is now detached. Gently pull it apart from the rest of the camera with your hands.
  4. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: 手順 4、 3の画像 1 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: 手順 4、 3の画像 2 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: 手順 4、 3の画像 3
    • Turn the side of the camera you just removed the cable ribbons from toward you.
    • The inner lining frame has an orange ribbon cable (circled in the image) that needs to be detached before it can be safely removed.
    • Remove the inner frame lining with tweezers.
    • Do so gently to avoid damaging the ribbon cable.
    • Carefully lift the inner frame lining away from the rest of the camera with your fingers.
  5. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: 手順 5、 2の画像 1 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: 手順 5、 2の画像 2
    • With the LCD screen removed, you should see a black metal plate. This can be pulled off to reveal the motherboard and the lens.
    • Use your fingers to gently lift the plate up and away from the rest of the camera.
  6. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: 手順 6、 2の画像 1 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: 手順 6、 2の画像 2
    • You should now be able to see the exposed motherboard and lens.
    • To separate the motherboard and lens, you must detach two more ribbon cables.
    • Remove the first ribbon cable (pictured first) with tweezers. Pull gently away from the camera.
    • Remove the second ribbon cable (pictured second) with tweezers. Pull gently away from the camera.
    • Use your fingers to gently lift the lens away from the motherboard and frame.
  7. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: 手順 7、 2の画像 1 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: 手順 7、 2の画像 2
    • Remove the screw (pictured first) with the #00 Phillips screwdriver.
    • Use tweezers to remove the last ribbon cable (pictured second). Pull gently away from the camera frame.
    • You should now be able to remove the motherboard from the base skeleton frame.
終わりに
2 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Scott Grambo
メンバー登録日: 04/08/15
264 ポイント
2のガイドは作成済み
チーム
5 件のコメント
So what about the other parts not in your photos that fall ?
The bracket around the speaker and this little white part that fell out as soon as I lifted the back cover a little? can you please give more info
Kat - 返信
I'm also finding where was the white parts located. It seems that without this part, wx80 works well. If you found its location, please give me hint. Thanks.
Chung-Suh Ku -
Maybe this helps for the location of the white part: https://www.quora.com/What-does-the-insi...
Christian Urban - 返信
This is not complete disassembly pics. Not at all. This is half the steps.
Mayur Panghaal - 返信
Huh?
How about the sensor? How do I clean the sensor?
jim dandy - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 26
今までの合計 2,437
