メインコンテンツにスキップ
Sony Cyber-shot DSC-WX80 Motherboard Replacement
必要な工具と部品
  1. Sony Cyber-shot DSC-WX80 Motherboard Replacement, Sony Cyber Shot WX80: 手順 1、 3の画像 1 Sony Cyber-shot DSC-WX80 Motherboard Replacement, Sony Cyber Shot WX80: 手順 1、 3の画像 2 Sony Cyber-shot DSC-WX80 Motherboard Replacement, Sony Cyber Shot WX80: 手順 1、 3の画像 3
    • Remove all six #00 screws holding the outer chassis together with a Phillips #00 screwdriver.
    • Keep track of all screws as they are small and very easy to lose
  2. Sony Cyber-shot DSC-WX80 Motherboard Replacement: 手順 2、 3の画像 1 Sony Cyber-shot DSC-WX80 Motherboard Replacement: 手順 2、 3の画像 2 Sony Cyber-shot DSC-WX80 Motherboard Replacement: 手順 2、 3の画像 3
    • At this point most of the parts in the camera should be free moving.
    • Take note of the small free moving flap near the battery port seen in the first of the three photos.
    • Remove the front of the shell case with the spudger. Insert the spudger into the seam on the right side of the camera and pry away from the back case.
    • Using the spudger, repeat the process to remove the back of the case. Pry away from the front of the camera.
  3. Sony Cyber-shot DSC-WX80 Motherboard Replacement: 手順 3、 3の画像 1 Sony Cyber-shot DSC-WX80 Motherboard Replacement: 手順 3、 3の画像 2 Sony Cyber-shot DSC-WX80 Motherboard Replacement: 手順 3、 3の画像 3
    • Turn the camera so that you are looking at the LCD screen.
    • Use tweezers to remove the first of two ribbon cables holding the LCD screen in place. Pull directly out of the port.
    • Use tweezers to remove the second of the two ribbon cables using the same method.
    • Take care not to tear the ribbons. They are the communication networks that your screen uses to operate.
    • The LCD screen is now detached. Gently pull it apart from the rest of the camera with your hands.
  4. Sony Cyber-shot DSC-WX80 Motherboard Replacement: 手順 4、 3の画像 1 Sony Cyber-shot DSC-WX80 Motherboard Replacement: 手順 4、 3の画像 2 Sony Cyber-shot DSC-WX80 Motherboard Replacement: 手順 4、 3の画像 3
    • Turn the side of the camera you just removed the cable ribbons from toward you.
    • The inner lining frame has an orange ribbon cable (circled in the image) that needs to be detached before it can be safely removed.
    • Remove the inner frame lining with tweezers.
    • Do so gently to avoid damaging the ribbon cable.
    • Carefully lift the inner frame lining away from the rest of the camera with your fingers.
  5. Sony Cyber-shot DSC-WX80 Motherboard Replacement: 手順 5、 2の画像 1 Sony Cyber-shot DSC-WX80 Motherboard Replacement: 手順 5、 2の画像 2
    • With the LCD screen removed, you should see a black metal plate. This can be pulled off to reveal the motherboard and the lens.
    • Use your fingers to gently lift the plate up and away from the rest of the camera.
  6. Sony Cyber-shot DSC-WX80 Motherboard Replacement: 手順 6、 2の画像 1 Sony Cyber-shot DSC-WX80 Motherboard Replacement: 手順 6、 2の画像 2
    • You should now be able to see the exposed motherboard and lens.
    • To separate the motherboard and lens, you must detach two more ribbon cables.
    • Remove the first ribbon cable (pictured first) with tweezers. Pull gently away from the camera.
    • Remove the second ribbon cable (pictured second) with tweezers. Pull gently away from the camera.
    • Use your fingers to gently lift the lens away from the motherboard and frame.
  7. Sony Cyber-shot DSC-WX80 Motherboard Replacement: 手順 7、 2の画像 1 Sony Cyber-shot DSC-WX80 Motherboard Replacement: 手順 7、 2の画像 2
    • Remove the screw (pictured first) with the #00 Phillips screwdriver.
    • Use tweezers to remove the last ribbon cable (pictured second). Pull gently away from the camera frame.
    • You should now be able to remove the motherboard from the base skeleton frame.
  8. Sony Cyber-shot DSC-WX80 Motherboard Replacement, Motherboard: 手順 8、 1の画像 1
    • Now that your motherboard has been removed you can replace it!
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
John Chastek
メンバー登録日: 04/06/15
116 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 5
今までの合計 788
