メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Disassembling Netatmo Outdoor Camera Main Unit
必要な工具と部品
  1. Disassembling Netatmo Outdoor Camera Main Unit, Main Unit: 手順 1、 2の画像 1 Disassembling Netatmo Outdoor Camera Main Unit, Main Unit: 手順 1、 2の画像 2
    • Remove the plate at the bottom of the camera by inserting a screwdriver in the slot, and bending while pulling.
    • The panel will lift up and can be removed.
    FixBotに聞いてみる
    コメントを追加
  2. Disassembling Netatmo Outdoor Camera Main Unit: 手順 2、 2の画像 1 Disassembling Netatmo Outdoor Camera Main Unit: 手順 2、 2の画像 2
    • Insert a flathead screwdriver into each hole at the front of the camera and push the two tabs to the centre and forwards.
    • It's hard to see, but you need the triangular part at the front, rather than what appears to be a tab at the back.
    • Pushing towards the centre allows the lens cover to come off. These can be done one at a time.
    FixBotに聞いてみる
    コメントを追加
  3. Disassembling Netatmo Outdoor Camera Main Unit: 手順 3、 2の画像 1 Disassembling Netatmo Outdoor Camera Main Unit: 手順 3、 2の画像 2
    • Remove the six 2.5mm hex screws using a long Allen key.
    • One screw has an earthing ring wire. Don't forget this when reassembling.
    FixBotに聞いてみる
    コメントを追加
  4. Disassembling Netatmo Outdoor Camera Main Unit: 手順 4、 2の画像 1 Disassembling Netatmo Outdoor Camera Main Unit: 手順 4、 2の画像 2
    • Separate the two pieces by pulling slightly on the lower module.
    • Pull the metal housing forward.
    • Pushing the light from the inside can help in removing the shell.
    FixBotに聞いてみる
    コメントを追加
  5. Disassembling Netatmo Outdoor Camera Main Unit: 手順 5、 1の画像 1
    • Using a 1.5mm hex screwdriver remove the four screws holding on the camera module.
    FixBotに聞いてみる
    コメントを追加
  6. Disassembling Netatmo Outdoor Camera Main Unit: 手順 6、 2の画像 1 Disassembling Netatmo Outdoor Camera Main Unit: 手順 6、 2の画像 2
    • From this point the housing can be worked up and diagonally to reveal the circuit board, and ribbon cable.
    • Be careful with both the camera module ribbon and the one for the LED lights (which cannot be removed).
    • Do not slide the circuit board within the heatsink otherwise you risk ripping the LED ribbon cable.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
The Virtual Traveller
メンバー登録日: 01/14/23
160 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 36
過去 30 日: 114
今までの合計 1,189
