メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Disassembling Logitech MX Mechanical
必要な工具と部品
  1. Disassembling Logitech MX Mechanical, Remove keycaps: 手順 1、 2の画像 1 Disassembling Logitech MX Mechanical, Remove keycaps: 手順 1、 2の画像 2
    この手順で使用する道具:
    Keycap Puller
    $6.95
    • Use a keycap remover tool / opening tool or your hands to remove all keycaps.
    • Make a few photos of your keybord layout to have a reference for reassembly later on.
    • If your keybord is dirty use a soft brush to clean it.
    FixBotに聞いてみる
    コメントを追加
  2. Disassembling Logitech MX Mechanical, Unscrew 20x black screws: 手順 2、 2の画像 1 Disassembling Logitech MX Mechanical, Unscrew 20x black screws: 手順 2、 2の画像 2
    • Remove 20x black screws with a Philips size 0 screwdriver.
    • Don't loose the screws, put them in a bin or similar.
    FixBotに聞いてみる
    コメントを追加
  3. Disassembling Logitech MX Mechanical, Open back cover: 手順 3、 3の画像 1 Disassembling Logitech MX Mechanical, Open back cover: 手順 3、 3の画像 2 Disassembling Logitech MX Mechanical, Open back cover: 手順 3、 3の画像 3
    • The back cover is held in place by small plastic tabs.
    • Flip the keyboard on its front.
    • There is a small slid between the back cover and the body. Insert a thin plastic opening pick at the top of the keyboard.
    • Use something sturdy, like a metal spudger to release the plastic tabs all around.
    • There is a cable comming from the battery and connecting the plastic cover and the keyboard front. The connecter is clipped into the plastic frame above the PCV and can be unclipped using some tweezers or spudger.
    FixBotに聞いてみる
    コメントを追加
  4. Disassembling Logitech MX Mechanical, Remove plastic frame above PCB: 手順 4、 3の画像 1 Disassembling Logitech MX Mechanical, Remove plastic frame above PCB: 手順 4、 3の画像 2 Disassembling Logitech MX Mechanical, Remove plastic frame above PCB: 手順 4、 3の画像 3
    • Disconnect controller from battery.
    • Disconnect ribbon cable from controller.
    • The plastic frame above the PCB is connected via screws. Unscrew 6x silver screws using a size 2 philips screwdriver.
    • Remove the black plastic frame covering the PCB.
    FixBotに聞いてみる
    コメントを追加
  5. Disassembling Logitech MX Mechanical, (Optional) Remove screws holding PCB: 手順 5、 2の画像 1 Disassembling Logitech MX Mechanical, (Optional) Remove screws holding PCB: 手順 5、 2の画像 2
    • There are 4 capped screws (silver) fixing the PCB to the metal part of the keyboard. One hides under the ribon cable.
    • Removing the switches isn't covered by this guide.
    • The switches for this model are Kailh Choc V2 Low Profile Switches.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
AnHeuermann
メンバー登録日: 08/26/24
411 ポイント
2のガイドは作成済み
5件のガイドコメント
Super vielen Dank. Wenn du mir jetzt noch sagen kannst, was ich machen muss, damit die Tastaturbeleuchtung immer an bleibt, wäre einfach cool
MasterOfTorment - 返信 共有
Can you publish a guide that shows how to best replace the switches? I have one switch that needs replacement, "9/". Thank you.
rrh - 返信 共有
@rrh87863 you mean like https://de.ifixit.com/Anleitung/Logitech... ?
It's in German and I didn't had the time to translate into English yet, but I'm sure your browser can translate it.
AnHeuermann - 返信 共有
I would like to replace the batter since mine stopped charging, is that doable?
stephendeo - 返信 共有
Hi Stephen,
Another user reported that replacing the battery in the mini version is the same as the full-sized keyboard (guide here). We don't know if the two keyboards use the same battery, though. If you have the chance, creating a guide for this would help everybody out!
Connor Bassolino - 返信 共有
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 107
過去 30 日: 541
今までの合計 9,613
