メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Disassembling InFocus LP435Z External Shell
必要な工具と部品
  1. Disassembling InFocus LP435Z External Shell, External Shell: 手順 1、 2の画像 1 Disassembling InFocus LP435Z External Shell, External Shell: 手順 1、 2の画像 2
    • Place the projector on its back (buttons down) with the lens facing away from you.
    • Remove the two 84mm screws in the upper left and right corners of the projector using the Phillips #2 screwdriver.
    • Remove the remaining three 8.5mm screws using the Phillips #1 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  2. Disassembling InFocus LP435Z External Shell: 手順 2、 2の画像 1 Disassembling InFocus LP435Z External Shell: 手順 2、 2の画像 2
    • Use the plastic opening tools to push down the clips holding the lamp cover in place, and remove it.
    • There is no lamp assembly in the projector used in this guide, yours may appear different.
    FixBotに聞いてみる
    コメントを追加
  3. Disassembling InFocus LP435Z External Shell: 手順 3、 2の画像 1 Disassembling InFocus LP435Z External Shell: 手順 3、 2の画像 2
    • Remove the two 8.5mm rear screws holding the rear case plate to the projector using the Phillips #1 screwdriver.
    • Pull the rear plate straight off and set it aside.
    FixBotに聞いてみる
    コメントを追加
  4. Disassembling InFocus LP435Z External Shell: 手順 4、 3の画像 1 Disassembling InFocus LP435Z External Shell: 手順 4、 3の画像 2 Disassembling InFocus LP435Z External Shell: 手順 4、 3の画像 3
    • Flip the projector over and turn around so that the lens faces you.
    • Twist the gray zoom adjustment ring clockwise and extend the lens all the way out, and then slide the zoom adjustment ring all the way towards the end of the lens as far as it will go.
    • Slide the front case plate towards the loosened zoom adjustment ring, until the top plate of the projector is freed from underneath the lip of the front case plate.
    • The front case plate will not come all the way off due to the zoom adjustment ring obstructing it. It will merely slide forward a bit.
    FixBotに聞いてみる
    コメントを追加
  5. Disassembling InFocus LP435Z External Shell: 手順 5、 2の画像 1 Disassembling InFocus LP435Z External Shell: 手順 5、 2の画像 2
    • Lift away the top case plate and set it aside.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Andrew Kennedy
メンバー登録日: 01/29/13
186 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 20-3, Maness Winter 2013 Cal Poly, Team 20-3, Maness Winter 2013人のメンバー
CPSU-MANESS-W13S20G3
4 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 30
今までの合計 1,615
