メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
DigiLand DL801W Screen Replacement
必要な工具と部品
  1. DigiLand DL801W Screen Replacement, Screen: 手順 1、 1の画像 1
    • Before opening your DigiLand Tablet, ensure that the MicroSD card is removed.
    • Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
    • Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
    • Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
    FixBotに聞いてみる
    コメントを追加
  2. DigiLand DL801W Screen Replacement: 手順 2、 1の画像 1
    • Once the back panel has been removed, it is best to set it aside in a safe location.
    • By using the J000 screwdriver, remove the 10 screws from the back. When the tablet is oriented like the picture, there are 6 screws to the left and 4 screws to the right. Set aside the screws in a safe place for re-installation.
    FixBotに聞いてみる
    コメントを追加
  3. DigiLand DL801W Screen Replacement: 手順 3、 3の画像 1 DigiLand DL801W Screen Replacement: 手順 3、 3の画像 2 DigiLand DL801W Screen Replacement: 手順 3、 3の画像 3
    • Disconnect the any wires that are connected to the motherboard.
    • Be careful not to damage any of the wires. If damaged, the tablet may not work correctly after repairing.
    FixBotに聞いてみる
    コメントを追加
  4. DigiLand DL801W Screen Replacement: 手順 4、 1の画像 1
    • Make sure not to damage the motherboard and components.
    • After removing all of the screws and disconnect any wires, use the blue plastic opening tool and starting from the bottom near the battery, carefully lift the back metal plate and motherboard out. Set aside in a secure place.
    FixBotに聞いてみる
    コメントを追加
  5. DigiLand DL801W Screen Replacement: 手順 5、 1の画像 1
    • After removing the motherboard, remove the LCD screen.
    • There are tabs around the LCD screen. Use the spudger to help remove.
    FixBotに聞いてみる
    コメントを追加
  6. DigiLand DL801W Screen Replacement: 手順 6、 1の画像 1
    • After removing the LCD screen, you should have four main components: The back cover, the motherboard and bracket, the LCD screen, and the front cover.
    • The screen is connected to the front cover. Carefully remove the cracked screen. The screen is connected by an adhesive.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
6 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Preston Bremer
メンバー登録日: 09/17/15
265 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 3-4, Harley Fall 2015 IUPUI, Team 3-4, Harley Fall 2015人のメンバー
IUPUI-HARLEY-F15S3G4
4 メンバー
10のガイドは作成済み
3件のガイドコメント
I can't find a replacement lcd screen mine has the rainbow colored liquid marks on the lcd and there's lines going across the screen i have the digiland model# DL801W 8" Windows 10 tablet
eachespeaches - 返信 共有
Yes Amazon supposedly has them for $19. I need one myself as it is cracked. The protection & cover not protect it.
Lilian Reitor - 返信 共有
Where can i find a replacement lcd display screen for digiland DL801W i do not need the digitizer i just need the inner lcd screen
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 36
今までの合計 3,075
