メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
DigMedia MusicStore CD-ROM Drive Replacement
必要な工具と部品
  1. DigMedia MusicStore CD-ROM Drive Replacement, Remove screws: 手順 1、 1の画像 1
    • Remove six Philips #2 screws from the bottom of the case.
    • REASSEMBLY CAUTION: To prevent thread stripping during reassembly, turn screws backwards slowly until you feel the screw thread drop into the original plastic thread, and only then, tighten screw normally but lightly - you're working with 20+ year-old plastics.
    FixBotに聞いてみる
    コメントを追加
  2. DigMedia MusicStore CD-ROM Drive Replacement, Disconnect top cover ribbon cable: 手順 2、 1の画像 1
    • Carefully fold the top and bottom open, revealing a ribbon cable connecting the two halves.
    • Unlock and disconnect the ribbon cable. Unlock by pulling the lock lever evenly on both sides, parallel to the board surface (not lift/pivot), in the direction of the ribbon cable.
    • When this ZIF (Zero Insertion Force) connector is properly unlocked, the ribbon cable should just fall right out of the socket (no need to pull with any strength).
    FixBotに聞いてみる
    コメントを追加
  3. DigMedia MusicStore CD-ROM Drive Replacement, Remove RF shield: 手順 3、 2の画像 1 DigMedia MusicStore CD-ROM Drive Replacement, Remove RF shield: 手順 3、 2の画像 2
    • Simply lift the RF shield off the unit.
    • When reinstalling, take note of the 6 fork-like interlocking clips around the edge of the shield, which should engage with the original positions.
    FixBotに聞いてみる
    コメントを追加
  4. DigMedia MusicStore CD-ROM Drive Replacement, CD-ROM cables and screws: 手順 4、 1の画像 1
    • Disconnect the digital audio connector (red) and the lid switch return connector (blue) from the logic board.
    • Unscrew four Philips #2 screws that secure the CD-ROM drive to the chassis.
    FixBotに聞いてみる
    コメントを追加
  5. DigMedia MusicStore CD-ROM Drive Replacement, Data and Power cables: 手順 5、 1の画像 1
    • Disconnect the large 40-pin IDE data connector and disconnect the 4-pin PC power connector from the CD-ROM drive.
    FixBotに聞いてみる
    コメントを追加
  6. DigMedia MusicStore CD-ROM Drive Replacement, Remove CD-ROM: 手順 6、 1の画像 1
    • Lift the CD-ROM drive out of the chassis.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Matt Falcon
メンバー登録日: 05/09/15
2,773 ポイント
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 18
今までの合計 235
