メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell XPS 720 H2C Graphics Card Replacement
  1. Dell XPS 720 H2C Graphics Card Replacement, Removing Dell XPS 720 H2C Cover Panel: 手順 1、 2の画像 1 Dell XPS 720 H2C Graphics Card Replacement, Removing Dell XPS 720 H2C Cover Panel: 手順 1、 2の画像 2
    • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
    FixBotに聞いてみる
    コメントを追加
  2. Dell XPS 720 H2C Graphics Card Replacement, Graphics Card: 手順 2、 2の画像 1 Dell XPS 720 H2C Graphics Card Replacement, Graphics Card: 手順 2、 2の画像 2
    • Locate the graphics card near the bottom-right area of the computer, just below the XPS processor cooler.
    • Before entering into the "guts" of the computer, make sure you have the computer powered off and unplugged. Following that, you will want to unplug any video cables, including DVI and VGA cables, that are connected to the graphics port on the back panel of the computer.
    • Some DVI cables may need to be unscrewed. This can simply be done by hand.
    FixBotに聞いてみる
    コメントを追加
  3. Dell XPS 720 H2C Graphics Card Replacement: 手順 3、 3の画像 1 Dell XPS 720 H2C Graphics Card Replacement: 手順 3、 3の画像 2 Dell XPS 720 H2C Graphics Card Replacement: 手順 3、 3の画像 3
    • Remove the support underneath the processor cooler by pressing down on the latch at the top of the support and pulling the support towards you.
    FixBotに聞いてみる
    コメントを追加
  4. Dell XPS 720 H2C Graphics Card Replacement: 手順 4、 1の画像 1
    • Continue by pressing down on blue tab restraining on the graphics card. In the picture the graphics card is shown to have the fourth blue clip from the top holding it in.
    • Pressing down on this clip will enable you to remove the graphics card from the motherboard.
    FixBotに聞いてみる
    コメントを追加
  5. Dell XPS 720 H2C Graphics Card Replacement: 手順 5、 1の画像 1
    • Unplug the cable labeled "P3" on the left side of the graphics card. Be sure to push the plastic pin all the way down and pull firmly.
    FixBotに聞いてみる
    コメントを追加
  6. Dell XPS 720 H2C Graphics Card Replacement: 手順 6、 1の画像 1
    • Grab the graphics card with two hands and pull directly outward. The card may not come out smoothly. If this is the case, apply firm and even pressure with both hands.
    • If you are reseating the graphics card, this is the time to clean it and make sure dust has been removed from the socket the graphics card sits in.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Colyn Dickson
メンバー登録日: 04/21/13
110 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 4-16, Maness Spring 2013 Cal Poly, Team 4-16, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S4G16
3 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 19
今までの合計 3,961
