はじめに
This guide will show you how to replace the battery for your Dell XPS 18 if it has failed.
必要な工具と部品
Turn the device on its screen.
Remove the ten 4mm screws using a T8 Torx screwdriver.
Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
Disconnect the black camera cable and pull it back to prevent future hassle.
Use the plastic opening tool's angled edge to remove the black and white wires connected to the wireless WLAN card.
14 の人々がこのガイドを完成させました。
9件のガイドコメント
needs the help to repair the Dell XPS18
anrew waleta - 返信 共有
It all worked good. Thanks.
My unit is missing the right foot stand. Is there anywhere else I can find the model number. Need to purchase a new power supply?
Also might need to replace the touchscreen its cracked. Have to power her up first to find out. Do you have a video for touchscreen replacement?
