メインコンテンツにスキップ
Dell XPS 17 9710 SSD Replacement
必要な工具と部品
  1. Dell XPS 17 9710 SSD Replacement, Prepare your device: 手順 1、 1の画像 1
    • For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the replacement. If your battery is swollen, take appropriate precautions.
    • Power off and unplug your laptop.
    • Close the display and flip the entire laptop upside-down, with the hinge facing away from you.
  2. Dell XPS 17 9710 SSD Replacement, Remove the lower case screws: 手順 2、 1の画像 1
    • Use a Torx T5 screwdriver to remove the eight 4.4 mm-long screws that secure the lower case.
    • The lower case is further secured by various clips that must be released before removal.
  3. Dell XPS 17 9710 SSD Replacement, Begin to release the clips: 手順 3、 3の画像 1 Dell XPS 17 9710 SSD Replacement, Begin to release the clips: 手順 3、 3の画像 2 Dell XPS 17 9710 SSD Replacement, Begin to release the clips: 手順 3、 3の画像 3
    • Insert an opening pick at the bottom left corner, between the lower case and the chassis.
    • Insert the flat end of a spudger into the gap created by the opening pick.
    • Pivot the spudger up to release the first set of retaining clips.
    • Repeat this process for the bottom right corner.
  4. Dell XPS 17 9710 SSD Replacement, Release the remaining clips: 手順 4、 3の画像 1 Dell XPS 17 9710 SSD Replacement, Release the remaining clips: 手順 4、 3の画像 2 Dell XPS 17 9710 SSD Replacement, Release the remaining clips: 手順 4、 3の画像 3
    • Insert an opening pick into the gap created on the front edge of the laptop.
    • Slide the opening pick around the entire perimeter of the laptop, prying up intermittently, until the lower case fully releases from the clips on the chassis.
  5. Dell XPS 17 9710 SSD Replacement, Remove the lower case: 手順 5、 3の画像 1 Dell XPS 17 9710 SSD Replacement, Remove the lower case: 手順 5、 3の画像 2 Dell XPS 17 9710 SSD Replacement, Remove the lower case: 手順 5、 3の画像 3
    • The lip of the lower case is very sharp. Handle it with care, and try not to slide your fingers along any of the edges.
    • Lift the lower case up and off of the chassis to remove it.
  6. Dell XPS 17 9710 SSD Replacement, Battery: 手順 6、 1の画像 1
    • Remove the seven 4.1 mm-long Phillips screws that secure the battery.
  7. Dell XPS 17 9710 SSD Replacement, Remove the battery: 手順 7、 3の画像 1 Dell XPS 17 9710 SSD Replacement, Remove the battery: 手順 7、 3の画像 2 Dell XPS 17 9710 SSD Replacement, Remove the battery: 手順 7、 3の画像 3
    • Use the flat end of a spudger to lift the front edge of the battery until you can easily grip it with your fingers.
    • Whenever you use a spudger or other sharp tools near the battery, be very careful not to accidentally poke or puncture it.
    • Lift the battery up and out of its recess to remove it.
  8. Dell XPS 17 9710 SSD Replacement, SSD: 手順 8、 1の画像 1
    • Remove the single 4.1 mm Phillips screw that secures the left side of the left SSD cover.
    • The screw securing the right side of the SSD cover was removed during the battery removal procedure.
  9. Dell XPS 17 9710 SSD Replacement: 手順 9、 3の画像 1 Dell XPS 17 9710 SSD Replacement: 手順 9、 3の画像 2 Dell XPS 17 9710 SSD Replacement: 手順 9、 3の画像 3
    • Remove the SSD cover.
    • With the SSD cover removed, the SSD will pop up at a shallow angle.
  10. Dell XPS 17 9710 SSD Replacement: 手順 10、 3の画像 1 Dell XPS 17 9710 SSD Replacement: 手順 10、 3の画像 2 Dell XPS 17 9710 SSD Replacement: 手順 10、 3の画像 3
    • Grip the free end of the SSD and pull it away from the socket to remove it.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD cover and screw.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
2 の人々がこのガイドを完成させました。
Connor Bassolino
メンバー登録日: 03/29/22
18,168 ポイント
82のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,788のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 38
今までの合計 837
