メインコンテンツにスキップ
Dell XPS 17 9710 Lower Case Replacement
必要な工具と部品
  1. Dell XPS 17 9710 Lower Case Replacement, Prepare your device: 手順 1、 1の画像 1
    • For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the replacement. If your battery is swollen, take appropriate precautions.
    • Power off and unplug your laptop.
    • Close the display and flip the entire laptop upside-down, with the hinge facing away from you.
  2. Dell XPS 17 9710 Lower Case Replacement, Remove the lower case screws: 手順 2、 1の画像 1
    • Use a Torx T5 screwdriver to remove the eight 4.4 mm-long screws that secure the lower case.
    • The lower case is further secured by various clips that must be released before removal.
  3. Dell XPS 17 9710 Lower Case Replacement, Begin to release the clips: 手順 3、 3の画像 1 Dell XPS 17 9710 Lower Case Replacement, Begin to release the clips: 手順 3、 3の画像 2 Dell XPS 17 9710 Lower Case Replacement, Begin to release the clips: 手順 3、 3の画像 3
    • Insert an opening pick at the bottom left corner, between the lower case and the chassis.
    • Insert the flat end of a spudger into the gap created by the opening pick.
    • Pivot the spudger up to release the first set of retaining clips.
    • Repeat this process for the bottom right corner.
  4. Dell XPS 17 9710 Lower Case Replacement, Release the remaining clips: 手順 4、 3の画像 1 Dell XPS 17 9710 Lower Case Replacement, Release the remaining clips: 手順 4、 3の画像 2 Dell XPS 17 9710 Lower Case Replacement, Release the remaining clips: 手順 4、 3の画像 3
    • Insert an opening pick into the gap created on the front edge of the laptop.
    • Slide the opening pick around the entire perimeter of the laptop, prying up intermittently, until the lower case fully releases from the clips on the chassis.
  5. Dell XPS 17 9710 Lower Case Replacement, Remove the lower case: 手順 5、 3の画像 1 Dell XPS 17 9710 Lower Case Replacement, Remove the lower case: 手順 5、 3の画像 2 Dell XPS 17 9710 Lower Case Replacement, Remove the lower case: 手順 5、 3の画像 3
    • The lip of the lower case is very sharp. Handle it with care, and try not to slide your fingers along any of the edges.
    • Lift the lower case up and off of the chassis to remove it.
終わりに
ある他の人がこのガイドを完成しました。
Connor
メンバー登録日: 03/29/22
12,543 ポイント
64のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,643のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 19
今までの合計 272
