メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Venue Pro Volume Button Replacement
必要な工具と部品
  1. Dell Venue Pro Volume Button Replacement, Back Cover: 手順 1、 1の画像 1
    • Slide the back cover up.
    • Lift the back cover away from the device completely.
    FixBotに聞いてみる
    コメントを追加
  2. Dell Venue Pro Volume Button Replacement, Battery: 手順 2、 2の画像 1 Dell Venue Pro Volume Button Replacement, Battery: 手順 2、 2の画像 2
    • Use your finger to lift the battery using the notch in the upper left corner of the compartment.
    FixBotに聞いてみる
    コメントを追加
  3. Dell Venue Pro Volume Button Replacement, Volume Button: 手順 3、 1の画像 1
    • Remove the Back Cover
    • Slide and lift the back cover off the phone. (Use the existing Back Cover Removal guide as reference)
    FixBotに聞いてみる
    コメントを追加
  4. Dell Venue Pro Volume Button Replacement: 手順 4、 1の画像 1
    • Remove the Battery
    • Lift the battery out of its compartment and set it aside.
    FixBotに聞いてみる
    コメントを追加
  5. Dell Venue Pro Volume Button Replacement: 手順 5、 2の画像 1 Dell Venue Pro Volume Button Replacement: 手順 5、 2の画像 2
    • Remove the Midframe Screws
    • Use a Phillips #00 screwdriver to remove the 4.57 mm screws securing the midframe to the phone.
    • Keep track of each screw and its original location to ensure correct reassembly.
    • Mixing screw lengths can damage internal components during reassembly.
    FixBotに聞いてみる
    コメントを追加
  6. Dell Venue Pro Volume Button Replacement: 手順 6、 2の画像 1 Dell Venue Pro Volume Button Replacement: 手順 6、 2の画像 2
    • Insert a plastic opening tool into the seam between the midframe and phone body.
    • Gently twist the tool to release the clips around the edges.
    • Once all clips have disengaged, pull the midframe upward to remove it completely.
    • If the midframe resists, continue sliding the tool along the seam until every clip releases.
    FixBotに聞いてみる
    コメントを追加
  7. Dell Venue Pro Volume Button Replacement: 手順 7、 1の画像 1
    • Expose the Motherboard
    • With the midframe removed, the motherboard should now be fully visible.
    • Identify the following components before continuing:
    • SIM card reader near the top of the device
    • Metal shielding covering the center of the motherboard
    • Micro-USB charging port at the bottom
    • Secondary daughterboard connection on the left side
    • Set the midframe aside.
    FixBotに聞いてみる
    コメントを追加
  8. Dell Venue Pro Volume Button Replacement: 手順 8、 2の画像 1 Dell Venue Pro Volume Button Replacement: 手順 8、 2の画像 2
    • Disconnect Internal Cables
    • At this point, the motherboard should be fully visible, as shown in your reference photos. You should see:
    • Disconnect the following cables:
    • Display cable
    • Any remaining flex cables attached to the motherboard
    • Lift connectors straight up—do not pull on the cables.
    FixBotに聞いてみる
    コメントを追加
  9. Dell Venue Pro Volume Button Replacement: 手順 9、 2の画像 1 Dell Venue Pro Volume Button Replacement: 手順 9、 2の画像 2
    • Remove the Motherboard Screws
    • Use a Phillips #00 screwdriver to remove the 2.68 mm screws securing the motherboard to the frame.
    • Screws are located near:
    • The bottom right corner (charging port area)
    • The middle left side
    • The top of the motherboard
    • Set all screws aside.
    • Using longer screws in motherboard locations can cause permanent damage.
    FixBotに聞いてみる
    コメントを追加
  10. Dell Venue Pro Volume Button Replacement: 手順 10、 2の画像 1 Dell Venue Pro Volume Button Replacement: 手順 10、 2の画像 2
    • Starting from the top edge, gently lift the motherboard up and away from the phone housing.
    • The micro-USB charging port may fit snugly in its opening. Lift carefully to avoid bending the board.
    • Once free, remove the motherboard from the device. Set the motherboard aside.
    • Do not flex or twist the motherboard during removal.
    FixBotに聞いてみる
    コメントを追加
  11. Dell Venue Pro Volume Button Replacement: 手順 11、 2の画像 1 Dell Venue Pro Volume Button Replacement: 手順 11、 2の画像 2
    • Remove the Volume Button Assembly
    • Locate the volume button assembly along the side of the phone frame.
    • Lift the volume button assembly out of its recess.
    • The button contacts are delicate. Remove the assembly carefully.
    FixBotに聞いてみる
    コメントを追加
  12. Dell Venue Pro Volume Button Replacement: 手順 12、 1の画像 1
    • Install the New Volume Button Assembly
    • Place the replacement volume button assembly into the phone frame.
    • Ensure it sits flush and aligns correctly with the external button openings.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Todjay A Orr
メンバー登録日: 10/29/25
719 ポイント
5のガイドは作成済み
チーム
Purdue University Northwest, Team 3-7, Dieterle Fall 2025 Purdue University Northwest, Team 3-7, Dieterle Fall 2025人のメンバー
PNW-DIETERLE-F25S3G7
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 22
今までの合計 99
