はじめに
If your Dell VRP100 headset has a cracked, scratched or broken lens you are definitely going to want to replace it. This guide has all the steps for you need replace those beat up lenses with new ones. You will need a metal spudger for parts of this guide.
必要な工具と部品
Remove the black foam padding by peeling away slowly.
Remove the front and back padding from the headset by peeling away slowly.
ある他の人がこのガイドを完成しました。
