必要な工具と部品
Slide the battery release latches toward each other to lock them in an open position.
Slide the battery out of the battery bay.
Loosen the captive screw.
Slide the bottom of the base assembly away from the hinge covers, and lift to remove the bottom of the base assembly.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
Remove the memory module from the connector.
