はじめに
This guide will teach you how to disassemble your Dell Precision 3510 laptop to replace the display assembly. Check out the Troubleshooting Pages and confirm that the display assembly will need to be replaced.
Before you begin the steps to replace the Dell Precision 3510 computer's display assembly, power the computer off completely and unplug any external devices. You can power off your computer by holding down the power button in the upper right-hand corner of the keyboard for 10-15 seconds.
必要な工具と部品
Flip the computer over so that you are looking at the bottom.
Use a Phillips #000 screwdriver to remove the eight 6.5 mm screws from the base cover.
Use a Phillips #000 screwdriver to remove the single 3 mm screw from the metal bracket that secures the power port.
Use a Phillips #000 screwdriver to remove the single 3 mm screw securing the metal bracket to the WLAN card.
Remove the metal bracket from the system board.
Use a Phillips #000 screwdriver to remove the 6.5 mm screws from each display hinge bracket.
Remove the two hinge brackets from the computer.
