メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Inspiron Duo RAM Replacement
必要な工具と部品
  1. Dell Inspiron Duo RAM Replacement, Front Cover: 手順 1、 2の画像 1 Dell Inspiron Duo RAM Replacement, Front Cover: 手順 1、 2の画像 2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
    • To remove the old battery from the laptop, first unscrew the eight screws (size M2.5x8) from the bottom with a Phillips #0 screwdriver, this will allow the removal of the keyboard and front panel.
    FixBotに聞いてみる
    コメントを追加
  2. Dell Inspiron Duo RAM Replacement: 手順 2、 2の画像 1 Dell Inspiron Duo RAM Replacement: 手順 2、 2の画像 2
    • Flip the device over again and open the laptop so that you have access to the keyboard. There are hooks on the bottom of the keyboard, but gently pulling the keyboard towards the monitor will allow it to pull out easily. Be sure to unclamp the ribbon cable. Remove the three screws under the keyboard.
    • Remove the three plastic Keyboard and trackpad connectors (these are labeled with a blue circle on the second photograph).
    FixBotに聞いてみる
    コメントを追加
  3. Dell Inspiron Duo RAM Replacement: 手順 3、 2の画像 1 Dell Inspiron Duo RAM Replacement: 手順 3、 2の画像 2
    • Next, remove the top cover from the device using the plastic opening tools. It snaps in on the sides, so don't worry if you hear it unsnapping; it's not breaking.
    FixBotに聞いてみる
    コメントを追加
  4. Dell Inspiron Duo RAM Replacement, RAM: 手順 4、 1の画像 1
    • With the cover removed, locate the 2GB RAM stick. It will be in the upper-middle portion of the device. The RAM stick is the flat blue rectangular object that has four black squares running along it vertically (for convenience, the RAM stick has been outlined in red in the photo).
    FixBotに聞いてみる
    コメントを追加
  5. Dell Inspiron Duo RAM Replacement: 手順 5、 2の画像 1 Dell Inspiron Duo RAM Replacement: 手順 5、 2の画像 2
    • There are two white spring levers on either side of the RAM. Pull them out gently to release the RAM. This will cause the RAM to stick up at a forty-five degree angle.
    • With the RAM at a forty-five degree angle, gently pull it straight out of the device.
    FixBotに聞いてみる
    コメントを追加
  6. Dell Inspiron Duo RAM Replacement: 手順 6、 2の画像 1 Dell Inspiron Duo RAM Replacement: 手順 6、 2の画像 2
    • With the RAM stick flipped up, carefully lift it out of the slot.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Steven Luther
メンバー登録日: 06/23/15
778 ポイント
3のガイドは作成済み
チーム
UW Tacoma, Team 1-1, Liner SU 2015 UW Tacoma, Team 1-1, Liner SU 2015人のメンバー
UWT-LINER-SU15S1G1
3 メンバー
6のガイドは作成済み
2件のガイドコメント
Good effort, but incomplete. Laptop parts can be very easily damaged, so removing all the screws is important.
Chiel Kersten - 返信 共有
Good evening!!!
Is it possible to install a M.2 or NVME SSD in this netbook model?
Greetings and blessings from Venezuela!!!!
Edwin Guerra Avendaño - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 30
今までの合計 2,797
