はじめに
This guide is intended to demonstrate the removal and replacement of the keyboard in the Dell Inspiron 3148. The procedure may be missing some steps. In Step 21, most of the components have been removed from the keyboard/case assembly. However, the speakers and trackpad still remain, and can be replaced on the keyboard/case assembly if salvageable. Furthermore, it is possible the keyboard can be removed from the case and replaced independently. If you find this to be the situation, consider revising this guide to include the additional steps. Thanks!
必要な工具と部品
Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
Flip the device over so the backside is facing you.
Remove the three 4mm screws holding battery in place using the Phillips #0 screwdriver.
If there is a piece of tape connecting the hard drive and a small power cord, remove the tape.
Using the Phillips #0 screwdriver, remove the two 4mm screws.
Using a pair of tweezers, lift the exposed edge of the CMOS battery upward.
Once the CMOS battery has been loosened, remove it from the device.
手順18 Motherboard
注意: 手順 18-20 は、作業進行中としてマークされている ガイド から引用されています。
Remove the keyboard cable from its ZIF connector by flipping up the locking tab on the connector and then pulling the cable out.
Using a Phillips #000 screwdriver, remove single 4.1mm screw from the SD card reader board.
Remove the SD card reader board.
Remove the keyboard.
ある他の人がこのガイドを完成しました。
