はじめに
This guide takes a step by step process on removal and replacement of the mother board on the Dell Inspiron 3148. The tools and hardware used/removed are listed ahead of the guide and referenced throughout each step.
必要な工具と部品
Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
Flip the device over so the backside is facing you.
Remove the three 4mm screws holding battery in place using the Phillips #0 screwdriver.
If there is a piece of tape connecting the hard drive and a small power cord, remove the tape.
Using the Phillips #0 screwdriver, remove the two 4mm screws.
Remove the keyboard cable from its ZIF connector by flipping up the locking tab on the connector and then pulling the cable out.
ある他の人がこのガイドを完成しました。
