メインコンテンツにスキップ
Dell Inspiron 13-7352 Battery Replacement
必要な工具と部品
  1. Dell Inspiron 13-7352 Battery Replacement, Battery: 手順 1、 3の画像 1 Dell Inspiron 13-7352 Battery Replacement, Battery: 手順 1、 3の画像 2 Dell Inspiron 13-7352 Battery Replacement, Battery: 手順 1、 3の画像 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Battery Replacement: 手順 2、 2の画像 1 Dell Inspiron 13-7352 Battery Replacement: 手順 2、 2の画像 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Battery Replacement: 手順 3、 1の画像 1
    • Gently remove the battery from the rest of the device.
終わりに
For optimal performance, after completing this guide, calibrate your newly installed battery.
8 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Mikinna Martin
メンバー登録日: 09/25/15
458 ポイント
2のガイドは作成済み
チーム
University of Tampa, Team 1-5, Whiteside Fall 2015 University of Tampa, Team 1-5, Whiteside Fall 2015人のメンバー
UT-WHITESIDE-F15S1G5
3 メンバー
6のガイドは作成済み
3 件のコメント
Last I looked up for a different model there was a video..
pc2053 - 返信
Hello,
My Dell Inspiron 13-7352 won't turn on; I was using it when there was power outage and I totally drained the battery and it went off automatically, after the power came back I charged it the whole night but it still totally doesn't turn on. I tried to long-press the power button but nothing happens. I am 99% sure that the reason was using it on battery until the whole charge was gone. Please help!
jobgondwe - 返信
My Dell did the same thing. I followed the above instructions to remove the battery and then put it right back in. Plugged into power and wa-la...it powered up. So simple. Thanks.
pcoladeb - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 25,000
