メインコンテンツにスキップ
Dell Chromebook 5190 Battery Replacement
必要な工具と部品
  1. Dell Chromebook 5190 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Before starting, please make sure you have disconnected and removed all devices populating the laptop's ports.
    • Remove the nine M2.5x7.5 screws located on the bottom side of the laptop.
  2. Dell Chromebook 5190 Battery Replacement: 手順 2、 3の画像 1 Dell Chromebook 5190 Battery Replacement: 手順 2、 3の画像 2 Dell Chromebook 5190 Battery Replacement: 手順 2、 3の画像 3
    • Be cautious, the following instructions are to prevent cracking the base cover.
    • With the opening tool, pry open the upper left corner by the laptop hinge.
    • With the opening tool, pry open the upper right corner by the laptop hinge.
    • Lift off base cover.
  3. Dell Chromebook 5190 Battery Replacement: 手順 3、 2の画像 1 Dell Chromebook 5190 Battery Replacement: 手順 3、 2の画像 2
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top left side of the battery.
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top right side of the battery.
  4. Dell Chromebook 5190 Battery Replacement: 手順 4、 2の画像 1 Dell Chromebook 5190 Battery Replacement: 手順 4、 2の画像 2
    • Remove the clear adhesive tape on the system board from the battery cable from where it's seated above the battery.
    • Pull out the keyboard cable toward you to disconnect it.
  5. Dell Chromebook 5190 Battery Replacement: 手順 5、 2の画像 1 Dell Chromebook 5190 Battery Replacement: 手順 5、 2の画像 2
    • Remove the black adhesive tape on the system board from the battery cable.
    • Dismount the cable from where it's seated above the battery.
  6. Dell Chromebook 5190 Battery Replacement: 手順 6、 3の画像 1 Dell Chromebook 5190 Battery Replacement: 手順 6、 3の画像 2 Dell Chromebook 5190 Battery Replacement: 手順 6、 3の画像 3
    • Unscrew and remove the four M2x3 screws on each corner of the battery.
    • Dismount the battery.
終わりに
作成者
3人の作成者と共同で作成されました。
Denise Cano
メンバー登録日: 02/10/22
617 ポイント
4のガイドは作成済み
チーム
Gateway, Team 1-3, Pee Spring 2022 Gateway, Team 1-3, Pee Spring 2022人のメンバー
GCC-PEE-S22S1G3
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 616
